stupid question but how fo i take out the center console
Old Sep 30, 2001 | 10:07 AM
JoshRambo's Avatar
Default stupid question but how fo i take out the center console
title explains it all. i mnust be missing some screws. can someone please tell me where and how many there are so i can take it out
thanks
josh
Old Sep 30, 2001 | 10:24 AM
BUSAFREAK's Avatar
Default Re: stupid question but how fo i take out the center console (Gravity)
You will need a steel malot and the biggest pry bar you can find...
Pop out the little square cover under the e-brake handle, remove 2 screws. on the sides of the console there should be 2 black smaller phillips screw.
Old Sep 30, 2001 | 11:10 AM
Jason's Avatar
thanks
josh
there's two on each side by the rear (you have to move the front seats up), there's one on each side all the way at the front, and then you have to use a flat head and pry up the plastic piece under the e brake (there's two more under there)
you then have to pull out the ashtray and I believe there are around 4 there ( I have mine out and a Fields there, so I can't remember exactly)
that should be it, just lift the rear portion of it out after you take the screws out by the e brake and the rest just pops out....
hope this helps
Old Sep 30, 2001 | 12:28 PM
tatty's Avatar
New User
Default Re: stupid question but how fo i take out the center console (plugg)
how about putting center console back? my ash tray is loose and i have a couple of clips. where do they go?
You want to take out just the armrest portion? or the whole thing? Either case, you need to remove the armrest first, as mentioned.
If you just want to remove your ashtray and cigarette lighter, remove the ashtray and you should find two screws behind. Loosen those and proceed to tug the whole ashtray/cigarette lighter out. You'll find a plug for the cig. lighter, just unplug that and on the top portion there should be two protruding pieces of plastic, where the clips go.
If you want to remove the whole plastic piece, there are screws on each side where your right knee, or passenger left knee would be...unscrew them. From removing the ashtray/ciglighter portion, there will be screws visible on each top corner. Unscrew those and you should be able to wiggle out the whole plastic portion surrounding the radio, shifter etc...
I apologize for the lame directions...
Old Sep 30, 2001 | 01:30 PM
JoshRambo's Avatar
Default Re: stupid question but how fo i take out the center console (tsaktuo)
thanks everyone. i didn't realize i hade to take the armrest off also. thats a lot of work just to replace the shift boot, but looks nice now with the red stiching.
graham_ott
Honda Civic (2001 - 2005)
Jun 29, 2015 10:12 AM
Ghost Shadow
Dec 30, 2007 10:15 AM
TypeRPinoY
Nov 28, 2002 07:57 PM
yellow blur
Feb 16, 2002 12:34 PM
Judah
Nov 21, 2001 08:22 AM
