Zex Dry Kit 2003 Accord
Does anyone know if the Zex Dry Kit will work on a 2003 Accord 2.4 liter engine? I'm not sure if I have a returnless fuel system, which supposed you can't run a dry kit with.
I would like to run the 50 to 75 shot....
Just got an email back from Zex and they said their wet kit will work. I've heard this kind is dangerous due to possible back fire up the intake.
Newbie to nitrous, please hook me up...
Well what ever u do unless you have engine management to alter your timing you can only use a 55shot zex doesnt not have 50 shot jets. More then55 shot or n20 requires you to retard your timing but cannot be done with stock ecu anything obd2 and newer will automatically return the timing to stock.
you have a far greater chance of leaning out a cylinder and detonating w/ a dry kit then you do with flooding your intake and backfiring with a wet kit as long as everything is installed and used properly. i have an NX kit as well and i love it
