92 4WS .. HELP ME
Old Jan 14, 2004 | 07:14 PM
IIBPIIprelude's Avatar
Default 92 4WS .. HELP ME
ok. speeda500 u said u had an extra h22.. i need details. what r the specs on the Euro engine? how much is that.
If i change my ecu... do u lose my 4WS !? or do i gain ATTS ? how does that work...
If i choose to keep my h23 what potential does it have?
ALSO wheres a good place to mount a tach. theres no room anywhere. the speakers in the dash take up way too much room.
thanks
i hate this " u can only send 5" crap. i have lots to ask
Old Jan 14, 2004 | 07:23 PM
Behan's Avatar
Default Re: 92 4WS .. HELP ME (IIBPIIprelude)
you should spend your time searching
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IIBPIIprelude &raquo;</TD></TR><TR><TD CLASS="quote">
If i change my ecu... do u lose my 4WS </TD></TR></TABLE>
if you use a non 4ws ecu, then yes you lose it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IIBPIIprelude &raquo;</TD></TR><TR><TD CLASS="quote"> or do i gain ATTS ? how does that work...
no you do not gain atts.
your h23 has potential, IMO a turbo for an h23 has more potential than an h22 swap
you need to do some research.
Old Jan 15, 2004 | 10:33 AM
xxxxxxxxxxxx's Avatar
Default Re: 92 4WS .. HELP ME (Behan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Behan &raquo;</TD></TR><TR><TD CLASS="quote">you should spend your time searching
you need to do some research.</TD></TR></TABLE>
Actually I was reading a post somewhere here that said that you wouldn't lose 4WS, but I'm not sure if the guy was right.
Old Jan 15, 2004 | 10:35 AM
AndyD's Avatar
Actually, he should not lose 4WS. I am going to be doing the swap VERY soon so I will post back if I lose my 4WS or not. I hope I don't. I love it....when it works.
Old Jan 15, 2004 | 10:39 AM
Sephro's Avatar
Default Re: 92 4WS .. HELP ME (AndyD)
I was kinda curious if you would or not... I mean there is the whole 4WS ECU in the trunk... Maybe look into a JDM 5th Gen 4WS ECU (sorry I don't know what they used.) but then you would get the speed limiter...
Old Jan 15, 2004 | 11:08 AM
Riptide101's Avatar
Default Re: 92 4WS .. HELP ME (Sephro)
You won't lose your 4WS. I have done a VTEC swap into my 94 SI/4WS and have no problems. The 4WS is almost completely standalone. That computer behind the back seat controls everything for it.
Old Jan 15, 2004 | 11:16 AM
Sephro's Avatar
Default Re: 92 4WS .. HELP ME (Riptide101)
good to know. I was thinking that was the case because I thought the 4WS used the same ECU as the 2WS Si's
Old Jan 15, 2004 | 12:06 PM
Behan's Avatar
i though the 4ws models used a different ecu than the p14, but if you have first hand experience than , thanks for the correction.
Old Jan 15, 2004 | 01:06 PM
caLiH22A's Avatar
I can also help confirm that the 4WS will not be lost due to some of my experiences. I have used one of my friend's p13 which has a label on the ECU that reads different from mine. I also onced tried a friend's P28 ECU with I believe a Skunk2 program and neither time did I lose my 4WS. Like stated above, the 4WS has a mind of it's own.
oramac_eg
Dec 4, 2008 02:45 PM
egjdm1
Sep 3, 2008 06:37 AM
SEBASTEAN929
19
Apr 1, 2007 11:33 AM
buzz944
Dec 16, 2005 03:40 PM
rabbit94ludes
Jan 10, 2005 08:18 PM
