99 GSR into 92 EG Mount/Bracket Question *PICS*
Old Jan 14, 2004 | 06:12 PM
illmatik's Avatar
Default 99 GSR into 92 EG Mount/Bracket Question *PICS*
Thats a broken mount for the EG, its next to the AC on the driver side front. Do i get a GSR one??
thats the image of the bracket that wont fit on the GSR trans in the back, i dont know whether to get the Front or back bracket of the GSR Tranny, people are confusing me.
help will be appreciated, this is a swap GSR into EG thanks[/img][img]
Old Jan 14, 2004 | 06:49 PM
averageJoe's Avatar
Default Re: 99 GSR into 92 EG Mount/Bracket Question *PICS* (illmatik)
that first mount you can reuse any civic or integra rubber mount.
The second bracket is the front transmission bracket off of a D series transmission.
You need the front transmission bracket off of a 94+ B series transmission. (the lower hole will be in the middle of the upper 2 holes)
You ALSO need the rear transmission bracket off of an 94+ integra which looks like a (T)
Old Jan 14, 2004 | 06:56 PM
Nextelbuddy's Avatar
Default Re: 99 GSR into 92 EG Mount/Bracket Question *PICS* (averageJoe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by averageJoe &raquo;</TD></TR><TR><TD CLASS="quote">that first mount you can reuse any civic or integra rubber mount.
)</TD></TR></TABLE>
wrong...... please dont listen to him.
that mount u showed that is broken... thats the civic mount. you have to get the same mount for a civic to replace it. the integra one wont work. if u look at the flat part of the civic mont u will notice it is slightly recessed a littlebit to bolt up to the chassis. the integra one will not bolt up the flat part that bolts to the chassis is not recessed it is flat and straight accross. basicall with b series motor into eg civic. u need to keep the civic rubber mounts and use the b series tranny bracket and ac mount for it to work. the integra RUBBER mounts WILL NOT WORK.
hope that helps. i have done many swaps and never can i get that damn integra rubber mount to work.
Old Jan 14, 2004 | 07:35 PM
blazinb16's Avatar
That first mount dosent nessisaraly need to be replaced, it's not a load Baring mount it's just there to help stabilize, but if you want everything to be perfect go ahead and replace it.
Old Jan 14, 2004 | 08:31 PM
illmatik's Avatar
thanks abotu the front rubber mount, would i need a rear transmission bracket also or no??
Old Jan 15, 2004 | 07:07 AM
E-Rok's Avatar
EPIC TUNING
Default Re: (illmatik)
U can use a teg mount if you really HAD to. they just sit about 1/8th of an inch lower because its not recessed. if you in a jam, it will work.
1sikhatch
Apr 3, 2008 02:09 AM
4gencivicef9
Apr 16, 2007 04:37 PM
bboylito
Mar 15, 2005 08:44 AM
k24a4kid
Feb 13, 2005 03:49 PM
