Type r lsd in a ls tranny?
Old Jan 14, 2004 | 04:12 PM
streetlvlhatch's Avatar
Default Type r lsd in a ls tranny?
I just searched this topic and found some information, but was confused. I can get a good deal on a type r lsd and i currently have an ls tranny. Can anyone specify what parts are needed to complete this. It would be helpful to see something on acuraautomotiveparts.net as to what i need. thanks!!!!
Old Jan 14, 2004 | 04:18 PM
mmuller's Avatar
Mad Scientist
Default Re: Type r lsd in a ls tranny? (streetlvlhatch)
final drive and gsr or itr ring gear
Old Jan 15, 2004 | 10:13 AM
Default Re: Type r lsd in a ls tranny? (mmuller)
What do the final drvie and ring go for???? What is the ratio on the final drive that i need?
Old Jan 15, 2004 | 10:15 AM
mmuller's Avatar
Mad Scientist
well the final drive you ned because the differential on itr/gsr tranny is bigger than the ls...oh i forgot since you are changing the final drive (4.26 vs 4.4) you need a gsr/itr output shaft too
Old Jan 15, 2004 | 11:46 AM
so... basically this ends up being a pretty costly thing? Not worth it to go with this lsd? Would a quaife cost pretty much the same in the end?
Old Jan 15, 2004 | 01:07 PM
acy76's Avatar
If you check the parts site you mentioned, you'll need the ring gear (listed under clutch housing i think) and the counter shaft from a 94+ GSR to replace the final drive. Those 2 parts are a good way to start estimating prices. I don't know for certain whether all the LS gears fit the GSR countershaft.
Old Jan 15, 2004 | 05:21 PM
Kendall's Avatar
The quaife would probably save you a few bucks in the end, plus it's a better differential, but you won't get the benefit of the 4.40 final drive.
topshotta
Transmission & Drivetrain
Apr 24, 2012 08:36 PM
topshotta
Apr 24, 2012 12:26 PM
civicboy1128
Jun 18, 2008 04:24 AM
Nextelbuddy
May 19, 2004 07:26 AM
p1ccoloz
Mar 15, 2003 08:21 PM
