H22 and F22 question.
thanks any parts that will help peformance i know the 5 speed tranny will fit but Im looking to get a turbo soon and I want to upgrade alot of stuff first basically anything i can swap off the H22 onto the F22 for a nice peformance gain. the head would never work huh?
since your going to be boosting your f22, the only thing i can think of is the h22 stock throttle body. Any aftermarket flywheel of h22 should work w/ your f22 tranny. I cant really think of anything else that would help your future plan on boosting. Good luck man
thanks alot what year model throttle body will fit and how much HP would it help out with>? Would an H22 intake manifold fit ? what is the h23 cause i hear its better for 5 tranny. Would I need the whole H22 manifold or just get the throttle body what year model should I get?
just boost the stock F22.....talk to accordfreak.....hes got 14psi on a stock block. while i think thats pushing it, a stock f22 can take more than 7-8psi if its tuned properly
You really don't need to swap anything over. Just modify the existing parts.
The F series motors, especially the VTEC models, are very responsive with boost.
What about rods? I'm not an accord guy, but will the rods from an H22 or H23 swap over to F-series? If they do, are they any thicker than stock F-series?
i have had f22 tb on my h22 when i need to put somethign on an di ahve had h22 on my f22 when i had an extra
down the road you will want a bigger TB,
with the h22 you can run their intake at 3" and it would be more effictive
I think Sabastian just tried the H22 TB onto the F22 and it doesnt line up at all. Also you can sue the psitons but not the rods, the H23 rods you can use as well as the crank but the F22 crank is stronger than the H23.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97F22B2 »</TD></TR><TR><TD CLASS="quote">I think Sabastian just tried the H22 TB onto the F22 and it doesnt line up at all. Also you can sue the psitons but not the rods, the H23 rods you can use as well as the crank but the F22 crank is stronger than the H23.</TD></TR></TABLE>
eh... the H22 rods are slightly longer and the pistons are 2mm larger in diameter...than the F22
so without some machining & checking clearances neither of those will work in an F22...
The H23 rods are identical in length to F22... I dunno personally if they are any
different physically though...
Oh and this: <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by knowtomorrow3001 »</TD></TR><TR><TD CLASS="quote">This will be dumb and prove i know nothing and everyone will prob tell me not to post ever again but what parts off a H22 would fit my F22 2.2 Vtec Im so dumb.
No matter what anybody says... don't worry about it man...Ask away and search till your eyes hurt.... after asking tons of questions like the one you asked... you too can be a knowitall blowhard like some people who shall remain nameless...
Myself not included of course...
