how weak are rsx motor mounts?
Old Jan 14, 2004 | 03:15 PM
dc5 jared's Avatar
Default how weak are rsx motor mounts?
i drag race my car often, and i know im not the only one that drag races their rsx alot.. so someone must go through the same problems i do. in the past, launching at about 3 grand i would get aggressive wheelhop off the line and hitting second gear. i then stepped up and bought es motor mount inserts..which cured wheel hop for awhile then came back...
this past weekend i drag raced at fontana dragstrip...on nitto nt555r's at 17 psi launching at 4500...got crazy wheel hop on my last run. this week there have been clucking noises when i drive..i later brought the car to acura to get it diagnosied...they said that i have blown the rear motor mount..and the noise is my motor rocking in the engine compartment....has anyone encountered this problem..or am i the first??????????
-jared
Old Jan 14, 2004 | 04:43 PM
GoodKnight's Avatar
Default Re: how weak are rsx motor mounts? (sleeper dc5)
Many many people on clubrsx have blown either their front or rear mount. I tore my front. Just get the es motor mount inserts.
Old Jan 14, 2004 | 05:41 PM
dc5 jared's Avatar
Default Re: how weak are rsx motor mounts? (GoodKnight)
ummmm...if u read my first post...i bought es motor mounts, well before the rear mount blew.
Old Jan 14, 2004 | 07:07 PM
dacaveman's Avatar
How hard were the motor mount inserts to install?
Old Jan 14, 2004 | 07:11 PM
ITR_1211's Avatar
Could a torque damper help motor mounts from wearing out faster or tearing?
Old Jan 14, 2004 | 10:42 PM
dc5 jared's Avatar
Default Re: how weak are rsx motor mounts? (Darryl Musashi)
well i had the motor mount inserts installed at a shop called Autolink...charged me $100+ ....my next move is to fix the rear blown mount then order the j's engine dampener....cuz obviously the motor mount inserts alone weren't curing my wheel hop.
-jared
Old Jan 14, 2004 | 11:04 PM
alohasurftoad's Avatar
i don't even drive my car hard but bushings in my j's dampener kind of fell apart. so i had to find replacements. to me, the dampener puts stress on the stock motor mounts. if you drive your car hard the dampener won't last that long or the stock motor mounts will wear again. i think since you're having your motor mounts replaced anyway why not get racing motor mounts, not inserts.
Old Jan 14, 2004 | 11:23 PM
dc5 jared's Avatar
Default Re: how weak are rsx motor mounts? (alohasurftoad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alohasurftoad &raquo;</TD></TR><TR><TD CLASS="quote">i don't even drive my car hard but bushings in my j's dampener kind of fell apart. so i had to find replacements. to me, the dampener puts stress on the stock motor mounts. if you drive your car hard the dampener won't last that long or the stock motor mounts will wear again. i think since you're having your motor mounts replaced anyway why not get racing motor mounts, not inserts.</TD></TR></TABLE>
i dont think u understood what i wrote....i got inserts along time ago, when i started to bring this car to the dragstrip....my rear mount broke, and so the acura dealer is replacing it for free due to warranty. i am not getting new inserts to cure the problem...the inserts didnt work for me. so the next step is to get my car fixed and the dampener...frm what i hear the inserts and the dampener work pretty well. i obviously wont get race mounts because i simply dont want to pay for mounts.
Old Jan 15, 2004 | 04:52 AM
Mr.TecH7's Avatar
i have Hasport DC5 rear MM and they r some hefty son's of bilet bees. go race MM if u can, worth the $ching ching$
Old Jan 15, 2004 | 05:39 AM
dc5itracer's Avatar
Default Re: (Mr.TecH7)
Hasport has replacemebt mounts for the rsx need to check them out and sleeper maybe it was the shops fault they didnt torque em down properly and it probably came loose i had a torn rear mount and i installed my ee mm and havent had any problems with wheel hop and its been 5 months of hard driving no probs hey does anyone know if i can get the upper mount from mugen seperatly i want to change the upper left and right anyone make mounts i got two bottom(ee mm) i want uppers
Old Jan 15, 2004 | 07:53 AM
Mr.TecH7's Avatar
Default Re: (dc5itracer)
i think the mugen mm is $260 complete set, they look just like stock but diff bushings. sorry i don't know if they sell them sep
Old Jan 15, 2004 | 09:03 AM
dc5itracer's Avatar
But hasport has mounts for the dc5 all i see is for civic to bolt in k20a2
Old Jan 15, 2004 | 09:05 AM
Mr.TecH7's Avatar
call them, its not on the site...
dc5rr $150 shipped
Old Jan 15, 2004 | 09:08 AM
dc5itracer's Avatar
and thats just the rear one they dont have the front one
Old Jan 15, 2004 | 09:13 AM
Mr.TecH7's Avatar
yup just rear for now, they had a few kits out but had to stop production because there was too much vibration from engine... so back to the drawing board.
the rear mount takes the most stress
hasport said they should have replacment mm kit out by end of feb
Old Jan 15, 2004 | 09:25 AM
actually, i think i understand. you're fixing the blown mount and having es inserts installed as well as a j's dampener to supplement. the thing is, in my opinion the dampener won't tolerate constant hard driving. i figured since the car is going into the shop, to replace the blown mount, why not have them replace it with race mounts. es inserts and the torque dampener will be unnecessary.
Old Jan 15, 2004 | 09:51 AM
dc5itracer's Avatar
The olny other mounts available i think are mugen but there just stock with harder bushings and like mr. tech said the olny thing available is the rear lower mount bet bet is the ee mm and torque dampner for now till hasport has a complete kit
Old Jan 15, 2004 | 10:26 AM
dc5 jared's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alohasurftoad &raquo;</TD></TR><TR><TD CLASS="quote">actually, i think i understand. you're fixing the blown mount and having es inserts installed as well as a j's dampener to supplement. the thing is, in my opinion the dampener won't tolerate constant hard driving. i figured since the car is going into the shop, to replace the blown mount, why not have them replace it with race mounts. es inserts and the torque dampener will be unnecessary. </TD></TR></TABLE>
the only reason im not going to replace the mounts to race mounts is because my car is at the acura dealer...the dealer is fixing my car free of charge due to warranty. (sorry i should have been more specific)
hondatec1
Mar 9, 2012 03:33 AM
JUN JDM
Jul 13, 2003 08:11 PM
crashtest Sonny
Sep 22, 2002 02:25 AM
