apexi ws coilover
Old Jan 14, 2004 | 02:37 PM
fw190bvi's Avatar
Default apexi ws coilover
this may be a dumb ?.....but i need to know this quick, and cant find it anywhere......are the WS damper coilovers adj damper??? aka, is the shock adjustable, or just the ride height.....i might be picking up a set for $600 shipped
Old Jan 14, 2004 | 03:01 PM
RotaryBzzzz's Avatar
Default Re: apexi ws coilover (fw190bvi)
they are ride-height only adjustable. If your looking to compete, the GC/Koni's might be the way to go (though I'm very happy with my ws setup).
I would avoid the tokico's btw.
http://www.apexi-usa.com/suspension_wsdamper.asp
Old Jan 14, 2004 | 03:12 PM
fw190bvi's Avatar
Default Re: apexi ws coilover (RotaryBzzzz)
so ur on WS???....what do u think of them....im not looking to compete...just something to give me a lil bit tighter ride, and of course the joys of lowering....also, what sorta camber adj did u have to make, i plan on going mayb 1.75"-2" in the summer, and back to stock height in the winter and since they dont come w/ a new top mounting bracket, will i need new ones, or do the stock work fine??
Old Jan 14, 2004 | 04:51 PM
fw190bvi's Avatar
anyone else got any input???
Old Jan 14, 2004 | 05:26 PM
with quality coil-over kits, there are no camber issues. Zero....though toe-in/out could cause excess wear if you never get the car aligned (i've never though). You could drop the car on the ground and have no camber issues/tire wear issues...it's unlimited lowering.
I really like my ws...it's a tight ride but not teeth-rattling tight...my APEXi catalog says the springs are something like 40% stiffer than stock (from memory). On smooth roads, the ride feels like stock -smoo00000th.
I didn't use any new top-mounting brackets....I used the old ones off the stock part then zip-tied / clipped it with good quality industrial zips. Haven't had ANY issues at all.
What you COULD do if you have access to a self-serve junkyard is look for a 90-97 accord to strip these clips off if you wanted to absolutely save your old setup.
Custard512
May 12, 2010 11:27 AM
ntensehonda
Honda S2000
15
Dec 28, 2006 08:32 PM
Kicker773
Aug 26, 2004 07:43 AM
RedDragon
Mar 28, 2002 01:42 PM
