Mating a b16 intake manifold to a LS head ... Anyone..
Old Sep 30, 2001 | 01:02 AM
LsTurbo91's Avatar
Default Mating a b16 intake manifold to a LS head ... Anyone..
Has anyone succesfully mated a b16 intake manifold to a LS head?
Old Sep 30, 2001 | 01:53 AM
B18C-EJ1
Guest
Posts: n/a
Default Re: Mating a b16 intake manifold to a LS head ... Anyone.. (9psiLsT)
Do a search
In fact.......
https://honda-tech.com/zerothread?id=72378
[Modified by B18C-EJ1, 2:54 AM 9/30/2001]
Old Sep 30, 2001 | 09:30 AM
non-VTEC's Avatar
just buy a skunk 2 manifold.........unless you got a B16 manifold for free then it might be worth while........
Old Sep 30, 2001 | 10:16 AM
Bumnah's Avatar
Default Re: Mating a b16 intake manifold to a LS head ... Anyone.. (non-VTEC)
i'd get a skunk2 manifold if i were you.
but if you wanted to i guess you could chop the port that connect to your head off your stock ls intake manifold, and weld them onto your b16 manifold. i guess you could,but i'd get the skunk2 manifold. it's helluva lot better
Old Sep 30, 2001 | 10:28 AM
LsTurbo91's Avatar
Default Re: Mating a b16 intake manifold to a LS head ... Anyone.. (Bumnah)
Well, I already started it. It doesn't look too hard at all. I already took the middle stud off. I just gotta block of the coolant passage from the b16 intake manifold. grind a little on the bottom, tap a fitting on the 2 coolant passages. Then im done. I'll let you guys know how it comes out.
s.cha
Dec 19, 2009 05:40 PM
RICE POLICE SIP
Jan 15, 2003 01:08 PM
lsvtec4door
Aug 16, 2002 02:44 PM
Ri5e
Aug 1, 2002 12:46 AM
b18b25psi
Jul 30, 2002 08:23 PM
