B20V in eg6 DOESNT start!!!help>!?!?!
Old Jan 14, 2004 | 11:57 AM
phase12gsr's Avatar
Default B20V in eg6 DOESNT start!!!help>!?!?!
I have a b20 wit a 00 b16 head wit ctr int cam and gsr exh cam. My car was running for about a day before my spark plug fell out of the distributor and i flooded out and stalled. My car started up after i dry started it but after a block i stalled again. Now it really doesnt start. I have spark and fuel. Fuses and compression are good. Can anyone help me? I do pump out o2, knock and cyp codes but my car does have the correct timing. I also ran my car wit out knock and o2 sensors before too.. Help!!!!
Old Jan 14, 2004 | 03:51 PM
mmuller's Avatar
Mad Scientist
Default Re: B20V in eg6 DOESNT start!!!help>!?!?! (phase12gsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phase12gsr &raquo;</TD></TR><TR><TD CLASS="quote"> My car was running for about a day before my spark plug fell out of the distributor and i flooded out and stalled.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phase12gsr &raquo;</TD></TR><TR><TD CLASS="quote">and cyp codes
key word, try swapping dizzy's with a good working one
Old Jan 14, 2004 | 09:28 PM
ultimatehonda's Avatar
Yeah you may want to check the coil in the dizzy to make sure it hasnt died on you, and make sure everything is connected like it should be.
Old Jan 14, 2004 | 09:39 PM
mastarolla's Avatar
Default Re: B20V in eg6 DOESNT start!!!help>!?!?! (ultimatehonda)
set your timing right...it can make a big difference.
Could knock codes be coming due to incorrect cam timing also? The OBD II ECU i think goes into limp if O2 or knock code is there (if ECU is OBDII, im just assuming it is). If the motor is limping and the timing is off to boot, there is a likelyhood that most of your problem is right there.
Old Jan 15, 2004 | 01:33 AM
JohnnyXcalade's Avatar
Having trouble with your car Clifford? maybe I can help, give me a call you got my number.
THE BULL
Feb 4, 2008 01:22 AM
ek4ferrio
Jun 3, 2007 02:59 PM
dr_latino999
14
Aug 11, 2005 01:18 PM
Racerage1
34
Feb 13, 2005 04:21 PM
phase12gsr
Jan 14, 2004 11:47 AM
