Are all knock sensors the same
Old Jan 14, 2004 | 11:26 AM
tgreaves's Avatar
Default Are all knock sensors the same
Im looking for a knock sensor to work on a obd2 h22a prelude.. What other knock sensors will work.. I heard that all the single wire sensors are all the same but I just wanted to make sure of it..
Old Jan 14, 2004 | 12:53 PM
tgreaves's Avatar
Default Re: Are all knock sensors the same (tgreaves)
Bumpity.. bump bump
Old Jan 17, 2004 | 06:54 PM
PnX-R's Avatar
I'm not too sure on Hondas themselves. But from what I've learned, all Knock Sensors are not the same. Swapping sensors could be a bad thing because if it's too sensitive, the PCM will throw KS codes. But if it's not sensitive enough, you could ping and detonate and the PCM won't throw a code or adjust your ignition timing..
Maybe someone else might have a better answer as to swapping parts..
Old Jan 20, 2004 | 05:38 AM
tgreaves's Avatar
Default Re: Are all knock sensors the same (PnX-R)
Hmm.. Again im not too sure but I keep hearing that all the Honda single wire knock sensors are all the same.. Can anyone else vouch for this..
deucedeuceEK9
Feb 2, 2006 12:13 PM
MlnknprkrM
Nov 11, 2004 06:42 PM
evo
Mar 4, 2003 07:10 AM
memphiss13
Jul 1, 2002 10:14 PM
Plan B
May 28, 2002 11:33 PM
