What Cuases?
Old Jan 14, 2004 | 11:07 AM
DsCivicEx's Avatar
Default What Cuases?
Hey guys here I am agian working on the car. Hopefully one day ALL the quirks wil be worked out and you all will be to thank. Well I got my car running "better" by adjusting the TPS to the right voltage and all my check engine lights are gone BUT tell me what I need to fix with the cars idle jumps up and down but DOESNT trow a check engine light?
Old Jan 14, 2004 | 11:08 AM
=GAME='s Avatar
Default Re: What Cuases? (DsCivicEx)
vaccum leak or iacv
Old Jan 14, 2004 | 11:10 AM
976's Avatar
976
New User
Default Re: What Cuases? (O.G triple O.G)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by O.G triple O.G &raquo;</TD></TR><TR><TD CLASS="quote">vaccum leak or iacv </TD></TR></TABLE>
Yup, try cleaning the IACV. Use search to find poisons post on how to clean, really easy.
Or, you might be low on coolant, gives the same symptions of a bad idle as you described.
Old Jan 14, 2004 | 11:14 AM
DsCivicEx's Avatar
Default Re: What Cuases? (976)
Is the IACV bolted on the back of the intake manifold on a d16? just making sure I got the right parts in mind
horror's Avatar
maybe there is air trapped in the coolant system, i know this can cause an erratic idle.
Old Jan 14, 2004 | 11:15 AM
DsCivicEx's Avatar
hmmm coolant? could be cuase last time I started it I checked to make sure the heating system was running and I either didnt let it run long enough or my fans messed up cuase it never kicked on
976's Avatar
976
New User
Default Re: What Cuases? (horror)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by horror &raquo;</TD></TR><TR><TD CLASS="quote">maybe there is air trapped in the coolant system, i know this can cause an erratic idle.</TD></TR></TABLE>
Yup, this could cause it too.
Bleed your coolant system.
Old Jan 14, 2004 | 11:16 AM
DsCivicEx's Avatar
cool well thanks guys gave me lots of options to try Id never even thought of
Old Jan 14, 2004 | 11:20 AM
976's Avatar
976
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DsCivicEx &raquo;</TD></TR><TR><TD CLASS="quote">cool well thanks guys gave me lots of options to try Id never even thought of</TD></TR></TABLE>
Any time.
When I had my 90 prelude si, oh it was a good car... Anyway, it leaked coolant until it got low. Once low the idle bounced up and down until the engine was at operational temp. In really cold weather, even after it's warm the t/b could stay cold causing the idle serge.
Old Jan 14, 2004 | 11:21 AM
solsteeler's Avatar
Check the coolant for air bubbles,clean iacv,spray down and check for leaks.
Old Jan 14, 2004 | 12:21 PM
Do_Ster's Avatar
you might want to check your intake manifold gasket for leaks/cracks, my friend had a 240sx and that was the cause of his eratic idle
edit: i'm not sure if that would throw a check engine light or not, but just a suggestion. hopefully someone who knows will post and then i cna learn something new
Old Jan 14, 2004 | 12:37 PM
horror's Avatar
Default Re: (ntogethernow)
let us know what happens!!
milkmanLCA
Jan 27, 2010 05:22 PM
95civicohyeah
Oct 18, 2007 06:41 AM
96hatch87
Aug 25, 2007 03:06 PM
tpatt
Apr 28, 2007 05:21 AM
byronl
Jun 14, 2006 08:26 PM
