need help...valve noise??
Old Jan 14, 2004 | 10:57 AM
R91Si's Avatar
Default need help...valve noise??
just put b16 into 91 hatch...sounded like valves needed to be adjusted so i did...still have the noise intermittantly...before it was constant...what could it be???
Old Jan 14, 2004 | 11:00 AM
Jet Black's Avatar
Default Re: need help...valve noise?? (R91Si)
IMO you just didnt ajust the valves properly.
It took me 3 tries to get mine right, its kinda touchy.
Another possibility is your distro, it tends to make a noise like the valves clicking.
listen in on it
Old Jan 14, 2004 | 11:08 AM
R91Si's Avatar
could it be the lost motion assemblies?
Old Jan 14, 2004 | 11:11 AM
MLogan's Avatar
It might also be possible that some part of your valvetrain might be bent. When I took my head off and forgot to adjust them, it ran very bad. I had tightened them too much and after adjustment, I have some noise.
Old Jan 14, 2004 | 11:19 AM
Jet Black's Avatar
Default Re: (R91Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R91Si &raquo;</TD></TR><TR><TD CLASS="quote">could it be the lost motion assemblies?</TD></TR></TABLE>
I'll admit ignorance and say I have no clue what that is
Old Jan 14, 2004 | 11:27 AM
speed_racer012's Avatar
Default Re: (Jet Black)
what about your rocker arms? did you adjust those when you adjusted the valves?
I had the knocking noise with my zc and one of my rocker arms was really loose. tightened it up and it stopped. Just throwing that out there.
Old Jan 14, 2004 | 11:46 AM
phan's Avatar
Default Re: (R91Si)
i'd have to agree with this one. get the LMA's from an ITR and you'll be set.
Old Jan 14, 2004 | 11:54 AM
R91Si's Avatar
arent lost motion assy's like $30 a piece? and you need 8 of them!!
Old Jan 14, 2004 | 02:48 PM
mildly.interesting's Avatar
My valves don't make noise, but my Haltech, 770 cc injectors, and mad *** piston slap cover up all that valve train noise...
Old Jan 14, 2004 | 03:26 PM
RCautoworks's Avatar
Default Re: (phan)
Does the noise go away when you hit vtec ? If so it is probably the lma's.
Old Jan 14, 2004 | 05:01 PM
ef8powr91's Avatar
Default Re: (R91Si)
TRU....my b16 was loud as hell after 3 valve adjustments!....i got ITR LMA's and it went away...sounds smoooth as hell....they're kinda pricy at like 30 a piece for ITR's but i HEARD u can use prelude lma's which are cheaper (like under 100 for all 8!) but u might need to ask about that...hope i could help!
Old Jan 15, 2004 | 03:06 AM
R91Si's Avatar
havent driven it yet...(axles needed) but if it goes away then im goin with type r lma's
Old Jan 15, 2004 | 04:45 AM
Integ  u's Avatar
Default Re: (R91Si)
What is the lost motion assemblie? What does it do, if I may ask.
Old Jan 15, 2004 | 05:53 AM
USDM 4G VTEC's Avatar
Default Re: (Integ u)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Integ u &raquo;</TD></TR><TR><TD CLASS="quote">What is the lost motion assemblie? What does it do, if I may ask. </TD></TR></TABLE>
is this cylinder shaped bullet that goes on the valvetrain under the VTEC rocker arm
is function is to control the motion of the VTEC arm when is not in use , so it doesnt jump all around and is hard for vtec to kick in
(basic explanation)
Old Jan 15, 2004 | 05:59 AM
hahagasdcrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R91Si &raquo;</TD></TR><TR><TD CLASS="quote">just put b16 into 91 hatch...sounded like valves needed to be adjusted so i did...still have the noise intermittantly...before it was constant...what could it be???</TD></TR></TABLE>
Heres a post on LMA"s.........search is a fine tool
https://honda-tech.com/zerothread?id=726701
Old Jan 15, 2004 | 01:19 PM
R91Si's Avatar
anyone else had this problem???
mikeunreal2
Apr 21, 2006 10:15 PM
85civic
Aug 31, 2004 07:22 AM
DigitalFusion
Aug 5, 2004 07:29 PM
Bictorious
May 3, 2004 01:23 PM
