Torque Mount Question
Old Jan 14, 2004 | 10:24 AM
NAB16AEK's Avatar
Default Torque Mount Question
I am currently getting a b16 put in my ek (as we speak) Am I going to need torque mounts?? Or if not what is the deal with them?
Old Jan 14, 2004 | 08:06 PM
NAB16AEK's Avatar
Default Re: Torque Mount Question (NAB16AEK)
Anyone?
Old Jan 14, 2004 | 08:25 PM
racecarpete's Avatar
Yes, you need the torque mounts otherwise the motor will rock when you shift hard and your valve cover could hit your hood.
Old Jan 14, 2004 | 09:37 PM
GTlvr82's Avatar
Default Re: Torque Mount Question (SilverCivic2k)
It can and it does.....getting mine in a few days. Torque mounts are very important for launching.
Old Jan 16, 2004 | 06:41 AM
NAB16AEK's Avatar
Default Re: Torque Mount Question (GTlvr82)
What are some good torque mounts?
Old Jan 16, 2004 | 06:56 AM
elevatethis's Avatar
good torque mounts keep your motor from moving around, gives you a lot more traction on a launch *read: wheel hop.
jimfab and haasport make great mounts
energy suspension makes inserts but whether or not they'll work for the kit that you used to put the b16 in your EK I dont know.
I would definitly get torque mounts while you are putting the motor in, it will save you a headache later on, cause you will have traction issues once you start building the motor...
Old Jan 16, 2004 | 08:53 AM
TeamNextGenChris's Avatar
if i remember correctly,Katman broke the driver side upper mount off a motor once from not using the lower front torque mounts...
i have the aftermarket inserts(can't remember which brand)in mine and it works well.
chris
Old Jan 16, 2004 | 09:00 AM
SOHC_MShue's Avatar
I took out my drivers side lower torque mount when I was removing my ac because I thought it wasn't needed and my valve cover put a dent in my hood
Old Jan 16, 2004 | 09:03 AM
The Internet Tough Guy's Avatar
Default Re: Torque Mount Question (SOHC_MShue)
my passenger side torque mount is shot. i've been neglecting it for a little bit now, and my upper mount is wearing a good bit too. those forces have to go somewhere.
Old Jan 16, 2004 | 09:06 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">I took out my drivers side lower torque mount when I was removing my ac because I thought it wasn't needed and my valve cover put a dent in my hood </TD></TR></TABLE>
yeah,both side are definately needed.the upper driver and passenger mounts basically just hold the motor and provide a rotation point when the motor torques-they don't do anything to actually control the twist...the lower mounts and rear mount control how much it actually moves.i also found out the hard way when i had the top bolt out of the rear mount(figured it'd be okat until i got a new one) on my car,thinking the front mounts would keep the motor from moving around too much.the first time i shifted hard to 2nd gear,the two lower bolts in the rear mount ripped out of the tranny,taking with them a chunk of the case including where the shift linkage attaches.a new rear mount,new tranny case and new shift linkage later i realized it's PROBABLY a good idea to use ALL the mounts and ALL the bolts.
chris
Old Jan 16, 2004 | 09:12 AM
SOHC_MShue's Avatar
Default Re: Torque Mount Question (TeamNextGenChris)
yea man I shifted really hard into second with that mount off and it felt like my engine completely jumped and my shift felt so sloppy. I was like wtf is wrong with my car?! Thats when I saw that my hood had a small dent going outwards where a part of the valve cover had hit it...pisses me off man. I thought that the mount was just used to help support the ac compressor which I removed.
Old Jan 16, 2004 | 09:15 AM
SloCivicHMM's Avatar
I use the http://www.jimfab.com lower torque mounts and I love them...suppper still and can't beat the price...
Old Jan 16, 2004 | 10:19 AM
NAB16AEK's Avatar
Default Re: Torque Mount Question (SloCivicHMM)
would buy prothane or es inserts work/ help with engine movement?
Old Jan 16, 2004 | 10:32 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NAB16AEK &raquo;</TD></TR><TR><TD CLASS="quote">would buy prothane or es inserts work/ help with engine movement?</TD></TR></TABLE>
definately-i have them in my car and they really stiffened it up.added a lot of vibration at idle,but who cares.
chris
Old Jan 16, 2004 | 11:47 AM
NAB16AEK's Avatar
Do es have less vibes?
Old Jan 16, 2004 | 12:31 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NAB16AEK &raquo;</TD></TR><TR><TD CLASS="quote">Do es have less vibes?</TD></TR></TABLE>
to be honest with you-i'm not sure.i have the kit that includes inserts for the front lower torque mounts,and the rear chassis mount.been so long since i got them i can't remember if they're Prothane or ES.they do transmit quite a bit of vibration,but nothing you can't tolerate.motor is rock solid though.
chris
siriussr
12
Apr 15, 2009 10:56 AM
90Rexx
Mar 27, 2009 03:54 PM
Legion_2
Mar 3, 2009 09:58 PM
Civic*B16A3*Eg
May 4, 2007 04:38 PM
LilCivic04
Mar 6, 2006 03:33 AM
