AEM Fuel Rail Fitting Q
Old Jan 14, 2004 | 07:54 AM
Phaze2 Mike's Avatar
Default AEM Fuel Rail Fitting Q
car: 1995 Ex coupe
Setup: b16 w/bolt ons
Issue: Trying to put a AEM fuel rail on but the fitting they gave where youd normally put the fuel line on doesnt have a hole in it like the OEM fitting so if i just put the oem fuel line on it will simply just not flow.
Looking for the cheapest most effective way to use the oem fuel line. (Couldnt i just drill a hole in the ame fitting to make it like an oem fitting?
Old Jan 14, 2004 | 10:46 AM
Default Re: AEM Fuel Rail Fitting Q (yellowfever)
Really need help here
Old Jan 14, 2004 | 11:22 AM
976's Avatar
976
New User
Yes, you need to drill a hole for the FPR.
I hope I'm understanding you correctly.
Old Jan 14, 2004 | 11:41 AM
Default Re: AEM Fuel Rail Fitting Q (976)
not the fpr side, but where the oem fuel line that comes from the filter. On OEM fuel rail, u slide the ring at the end of the line over the fitting and tighten the bolt on. On aem u can slide the ring over but theres no hole for it to enter into, what should i do, just drill my own hole, does size matter?
Old Jan 14, 2004 | 11:58 AM
976's Avatar
976
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yellowfever &raquo;</TD></TR><TR><TD CLASS="quote">not the fpr side, but where the oem fuel line that comes from the filter. On OEM fuel rail, u slide the ring at the end of the line over the fitting and tighten the bolt on. On aem u can slide the ring over but theres no hole for it to enter into, what should i do, just drill my own hole, does size matter?</TD></TR></TABLE>
Holy crap, I would not drill the hole. If you're off by .01 mm you will see a gas leak. I don't want to see you die.
Post a pic, or contact AEM. You should have a hole either end of the rail, then three holes for the FPR.
I hope this helps.
EDIT: Yeah, a picture of the rail and the fuel feed line from filter would be very helpful just in case.
Old Jan 15, 2004 | 07:52 AM
TrboB16's Avatar
Yeay i wouldnt' drill a hole if you haven't figured it out yet you need to make a custom fuel line i can tell you what you need just post something back
Old Jan 15, 2004 | 11:21 AM
well aem expects u to make a new line? whats needed? could i just use a steelbraided fitting and cut the oem line?
Old Jan 15, 2004 | 11:26 AM
Marauder's Avatar
Default Re: (yellowfever)
Ummm....I might be outta line here....but why not call AEM and get the right one?!
There are different fittings based on your setup. Have you even checked whether or not your nut will even thread onto the end of that fitting or not. Honda has two different thread pitches depending on whether the OEM setup has a regular nut, or a pulse damper.
Old Jan 15, 2004 | 11:42 AM
Every honda fuel line from an 88 hf crx to a 2001 gsr has the ring at the end of it which slides onto the fuel rail, the nut fits the aem fitting but the fact remains theres no hole so puttting the fuel line on will flow nothing.
cityofcaterpillars
Apr 29, 2017 07:26 AM
Eg5ir1
Dec 17, 2012 09:46 PM
Slacker93eg
Aug 27, 2012 06:58 PM
tgreaves
Oct 15, 2003 01:39 PM
Que_Lude
Feb 2, 2003 10:07 PM
