97 EX motor mount questions?
Old Jan 14, 2004 | 04:45 AM
vabchaccord's Avatar
Default 97 EX motor mount questions?
Apparently, these things go bad pretty often, as I have been told mine have. Is it possible to get any kind of polyurethane motor mount such that vibration will be fixed and they will last longer, and, if so, where can I get them?
Old Jan 14, 2004 | 07:34 AM
Default Re: 97 EX motor mount questions? (vabchaccord)
Anyone?
Old Jan 14, 2004 | 10:05 AM
accordhybrid's Avatar
you can get the ES polyurathane mounts at http://www.summitracing.com
Old Jan 14, 2004 | 10:21 AM
Default Re: (accordhybrid)
Is it difficult to change those out, i.e. should I pay a shop to do it, or can I do it?
Old Jan 14, 2004 | 11:09 AM
m0t0rhead's Avatar
Default Re: (vabchaccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vabchaccord &raquo;</TD></TR><TR><TD CLASS="quote">Is it difficult to change those out, i.e. should I pay a shop to do it, or can I do it?</TD></TR></TABLE>
You can do it. But expect some vibration and interior rattling as a result.
Old Jan 14, 2004 | 01:26 PM
v4lu3s's Avatar
RTFM
what mount insert are youo looking for the front or rear?
Old Jan 15, 2004 | 03:06 AM
Default Re: (v4lu3s)
I'm in need of the front one, but, is there a tutorial or step-by-step somewhere I can use to do it? Also, can I just buy rubber inserts instead of polyurethane for the mount vs. buying the whole mount? (dealership wants to charge me ~$300 for the part and another ~$250 for the labor to install it.) I really just want to find some instructions so I can do it myself.
Old Jan 15, 2004 | 08:55 AM
m0t0rhead's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vabchaccord &raquo;</TD></TR><TR><TD CLASS="quote">I'm in need of the front one, but, is there a tutorial or step-by-step somewhere I can use to do it? Also, can I just buy rubber inserts instead of polyurethane for the mount vs. buying the whole mount? (dealership wants to charge me ~$300 for the part and another ~$250 for the labor to install it.) I really just want to find some instructions so I can do it myself.</TD></TR></TABLE>
Use a floor jack and a wooden board to support the motor.. take the nut off the bolt.. pull the bolt out.. put the inserts in.. put the bolt back in... put the nut on and tighten it up. Simple.
Old Jan 15, 2004 | 08:56 AM
Default Re: (Escobar)
Cool, thanx Escobar, what's the best place to support the motor so as not to injure it?
Old Jan 15, 2004 | 04:08 PM
m0t0rhead's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vabchaccord &raquo;</TD></TR><TR><TD CLASS="quote">Cool, thanx Escobar, what's the best place to support the motor so as not to injure it?</TD></TR></TABLE>
with a big board that covers the oil pan... support the pan.
Old Jan 15, 2004 | 10:30 PM
raceACCORDingly's Avatar
http://board.accordtuner.com/showthread.php?t=4310
Bk2fwd
Jun 26, 2005 07:51 PM
motormanSR
Jun 3, 2005 08:39 PM
josh3482
Jun 3, 2005 02:16 PM
xALL MOTORx
Feb 25, 2004 08:39 AM
IN2VTEC
Jun 26, 2002 03:54 PM
