TPS or IACV problem no codes w/rev goes up and down
Old Jan 13, 2004 | 06:51 PM
ibvietboi's Avatar
Default TPS or IACV problem no codes w/rev goes up and down
no codes... idles like 1k - 2k, replace the iacv wid a obd1 but needs a obd2.. i heard the obd1 will work... which fixed the problem when it got stuck at 3 rpm.. now it flux up and down, when i unplug the tps car idles good at 1k or 9 but check engine light is on...did a compression test.. and the results ... the two outside was the same and the two inside was alil bit lower +/-5.. i try to check vaccum by carb cleaner and seems like no leaks... when i check the tps for voltage i didnt get a reading, are u suppost unplug it and test ?
im getting really confused, this is my setup, 3bar map sensor w/hondata. no datalogger. jg intake manifold greddy turbo...
Old Jan 14, 2004 | 12:50 AM
Xsi's Avatar
Xsi
Is your TPS set? http://www.integra.orcon.net.nz/tps
Old Jan 14, 2004 | 12:54 AM
Katman's Avatar
Default Re: TPS or IACV problem no codes w/rev goes up and down (ibvietboi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ibvietboi &raquo;</TD></TR><TR><TD CLASS="quote">no codes... idles like 1k - 2k, replace the iacv wid a obd1 but needs a obd2.. i heard the obd1 will work... which fixed the problem when it got stuck at 3 rpm.. now it flux up and down, when i unplug the tps car idles good at 1k or 9 but check engine light is on...did a compression test.. and the results ... the two outside was the same and the two inside was alil bit lower +/-5.. i try to check vaccum by carb cleaner and seems like no leaks... when i check the tps for voltage i didnt get a reading, are u suppost unplug it and test ?
im getting really confused, this is my setup, 3bar map sensor w/hondata. no datalogger. jg intake manifold greddy turbo...</TD></TR></TABLE>
what year, make is your car ? and what engine are you running?
Old Jan 14, 2004 | 02:58 AM
leadfoot78's Avatar
Take off the IACV peace and clean the inside with degreaser and spray it with WD40 a little, see if that helps. My IACV is bad and I have a hunting idle too but just +/- 100rpm.
Old Jan 14, 2004 | 07:47 PM
Thagreybomber's Avatar
Default Re: (Xsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Xsi &raquo;</TD></TR><TR><TD CLASS="quote">Is your TPS set? http://www.integra.orcon.net.nz/tps</TD></TR></TABLE>
Great info, I'll be needing this....as soon as I can find a voltmeter
Old Jan 15, 2004 | 05:46 PM
ibvietboi's Avatar
i checked the tps ... good.... rechecked the iavc..good. i still get 1-2k rpm @ idle when warm.
when i unplug the tps, my check engine light will of course tun on and run smooth @ around 1k rpm. soo it cant be a vaccum leak right ? could it be the map sensor ? or ecu problem ? i have hondata but no datalogger. if it was the map how do i test that ? oh btw i have a gm 3 bar map
Old Jan 16, 2004 | 08:14 AM
Katman's Avatar
Default Re: (ibvietboi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ibvietboi &raquo;</TD></TR><TR><TD CLASS="quote">i checked the tps ... good.... rechecked the iavc..good. i still get 1-2k rpm @ idle when warm.
when i unplug the tps, my check engine light will of course tun on and run smooth @ around 1k rpm. soo it cant be a vaccum leak right ? could it be the map sensor ? or ecu problem ? i have hondata but no datalogger. if it was the map how do i test that ? oh btw i have a gm 3 bar map</TD></TR></TABLE>
I guess I'm talking to a brick wall... I'll reiterate...
Old Jan 16, 2004 | 10:37 AM
Darkteg's Avatar
New User
Default Re: (Katman)
i have the exact same symptoms, but idles goes from 1k to 1.4k
'98 euro ITR with P28 chipped ECU & JDM motor.
Old Jan 16, 2004 | 11:07 AM
ibvietboi's Avatar
its on my signature... thats y i didnt reply sorry... 92 si hb
Old Jan 16, 2004 | 12:28 PM
sick64nova's Avatar
do you have a cold start or fast idel on your t/b or on the mainifold under the t/b if you do take it off take the back cap off 2 8mm bolts and spin it in with a screw driver if it is not that you probley have a vacume leak check your vacume hoses and t/b gasket hopefully this helps if you need more info pm me .
All-Motor-Junkie
Jul 15, 2009 07:44 PM
92eg_MOB
Feb 28, 2009 05:12 AM
boostedgsteg
Oct 3, 2007 05:04 PM
v8 integra
Sep 18, 2007 04:55 PM
2camsaam
Oct 19, 2003 01:00 PM
