Help! Problem with Spoon Caliper/Brembo Rotor/ Axxis pad setup
Old Jan 13, 2004 | 06:43 PM
PYMUGENITR's Avatar
Default Help! Problem with Spoon Caliper/Brembo Rotor/ Axxis pad setup
Heres the deal, I had a new set of Brembo rotors and Axxis metal matrix pads installed today. It seems as though the brake pads are constantly rubbing against the calipers. I am running Spoon 4 pots as well. Anyone ever had this before? Suggestions? Any help would be great!
Old Jan 13, 2004 | 06:46 PM
thk's Avatar
thk
Members Only
Default Re: Help! Problem with Spoon Caliper/Brembo Rotor/ Axxis pad setup (PYMUGENITR)
Uhmm. Where is your washer set? Between the caliper and knuckle or just as a washer?
Old Jan 13, 2004 | 06:54 PM
PYMUGENITR's Avatar
Default Re: Help! Problem with Spoon Caliper/Brembo Rotor/ Axxis pad setup (thk)
Where should it be set?
Old Jan 13, 2004 | 06:58 PM
thk's Avatar
thk
Members Only
Where do you think it's supposed to be? I love it when people answers a question with a question.
Put it in between. You'll know if you set it right if the center line of the caliper lines up with the center of the rotor.
Old Jan 13, 2004 | 07:05 PM
2000 Integra R #760's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thk &raquo;</TD></TR><TR><TD CLASS="quote">Put it in between. You'll know if you set it right if the center line of the caliper lines up with the center of the rotor. </TD></TR></TABLE>
I had the same problem before. Thats is how i fixed mine.
Old Jan 13, 2004 | 07:11 PM
PYMUGENITR's Avatar
It's appears to be in the center. How far off would it be if it were off?
Old Jan 13, 2004 | 07:16 PM
thk's Avatar
thk
Members Only
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PYMUGENITR &raquo;</TD></TR><TR><TD CLASS="quote">It's appears to be in the center. How far off would it be if it were off?</TD></TR></TABLE>
And the washer is in between the caliper and the knuckle? It should be dead center of the rotor/smack dab in the middle of the cooling fins/vanes (the center line of the caliper, that is). And the amount it would be off by the thickness of the washer (I think it was like 2mm or something like that). If not, dunno what to say. Just go out and slam on the brakes a couple of times and wear those pads down. Heh heh heh.
But it has to be some type of install error, IMHO. If it's Type R specific rotors and pads, it should fit.
Old Jan 13, 2004 | 07:50 PM
PYMUGENITR's Avatar
Yes everything was Type R specific. I'll take a look at that. It looked to be in the center
Old Jan 13, 2004 | 07:58 PM
Mario's Avatar
But it has to be some type of install error, IMHO. If it's Type R specific rotors and pads, it should fit.</TD></TR></TABLE>
Sorry, not all pads made for a specific car are all created equal. Some pads (brand new) are much thicker than others.
Chances are you did install it correctly. Using the washer to center the caliper over the rotors, but the pads are just too thick.
Been there, done that. Good luck.
Old Jan 14, 2004 | 02:14 AM
whtdc2's Avatar
New User
Default Re: Help! Problem with Spoon Caliper/Brembo Rotor/ Axxis pad setup (Mario)
I don't have any problem with mine even the caliper is not sitting in the center. (as I have not money to buy a set of new wheels.. still need a 3mm spacer)
Old Jan 14, 2004 | 07:29 AM
thk's Avatar
thk
Members Only
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mario &raquo;</TD></TR><TR><TD CLASS="quote">Sorry, not all pads made for a specific car are all created equal. Some pads (brand new) are much thicker than others.
Been there, done that. Good luck.</TD></TR></TABLE>
True. I guess I haven't had that problem yet since every pad that I've purchased and tried out came in the correct size and thickness.
Old Jan 14, 2004 | 10:39 AM
PYMUGENITR's Avatar
What should be the stock pad thinkness?
Old Jan 14, 2004 | 12:01 PM
euclid's Avatar
Default Re: (PYMUGENITR)
brake pads do contact the rotors even if the brakes are not applied, you may need to break them in further. also the spoon calipers are know for pad rattle, that may be what you are hearing too.
Old Jan 14, 2004 | 12:07 PM
thk's Avatar
thk
Members Only
Stupid question #2 ...
Does the Axxis Metal Masters have the wear indicator tabs? If so were they removed?
Old Jan 14, 2004 | 12:42 PM
Denny's Avatar
Default Re: (thk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thk &raquo;</TD></TR><TR><TD CLASS="quote">Stupid question #2 ...
Does the Axxis Metal Masters have the wear indicator tabs? If so were they removed?</TD></TR></TABLE>
yes the do. you have to rip those off and shave the bump on the other side off.
Old Jan 14, 2004 | 04:11 PM
PYMUGENITR's Avatar
Found the problem was the ***** on the other side of the pads. Shaved them off and we are all good.
Thanks guys
Old Jan 14, 2004 | 04:14 PM
thk's Avatar
thk
Members Only
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PYMUGENITR &raquo;</TD></TR><TR><TD CLASS="quote">Found the problem was the ***** on the other side of the pads. Shaved them off and we are all good.
Thanks guys</TD></TR></TABLE>
The wear indicator tabs, huh?
Old Jan 14, 2004 | 07:43 PM
euclid's Avatar
Default Re: (thk)
i dont understand, why cant you have wear indicator tabs with the spoon calipers?
Old Jan 14, 2004 | 09:12 PM
thk's Avatar
thk
Members Only
Default Re: (euclid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by euclid &raquo;</TD></TR><TR><TD CLASS="quote">i dont understand, why cant you have wear indicator tabs with the spoon calipers?</TD></TR></TABLE>
It's not a sliding caliper design. The wear indicator tab sits inbetween the caliper and carrier. A fixed caliper design doesn't have that provision to put the tab.
It's not like you need it anyway with a fixed caliper. Just unmount a wheel and you can see how much pads you have left through the top.
CroSi
Suspension & Brakes
May 6, 2018 03:46 PM
KoRn_vIRuZ
Suspension & Brakes
Oct 22, 2015 11:11 PM
sato1
Jul 23, 2007 12:03 PM
EKRon
Jul 10, 2007 06:07 PM
ABTDer
Jun 10, 2003 01:17 PM
