LOTS and LOTS OF POPPING..!
Old Jan 13, 2004 | 05:12 PM
93FastLs's Avatar
Default LOTS and LOTS OF POPPING..!
I Finally got my car started..and now after starting the car...very rough idle..around 500-850 then the car trys to shut off. then after giving throttle through the throttle body. i hear alot of popping coming from the intake manifold.. and i mean alot..could it be a bent valve.. cause i did take the distributor off...to chek the coil maybe i didnt put back in right.. but if anyone know what the popping is and the low and rough idle is...would be a great deal of help...
Old Jan 13, 2004 | 05:43 PM
hondatim's Avatar
Default Re: LOTS and LOTS OF POPPING..! (93FastLs)
Sounds like you may have installed the plug wires in wrong firing order.
Old Jan 13, 2004 | 06:26 PM
doublejz's Avatar
Default Re: LOTS and LOTS OF POPPING..! (hondatim)
timing, plug wires, bad gas, if its a swap that you just completed might need to run for a bit. I had a couple engines that stumbled very bad for a while
Laserjock
Apr 3, 2010 07:20 PM
jdm_vizionz
Mar 2, 2010 10:49 AM
opg5009
Jun 4, 2007 11:12 AM
816d16
Nov 16, 2004 10:27 AM
user 996328629
Jun 9, 2003 07:18 PM
