Turbo Heat sheilds
Old Jan 13, 2004 | 02:28 PM
Justin Olson's Avatar
Default Turbo Heat sheilds
Anyone try these shields from advanced thermal products?
http://www.atpwrap.com/
Old Jan 13, 2004 | 02:32 PM
integranator's Avatar
Default Re: Turbo Heat sheilds (olsonjus)
looks pretty pimp-- bump for some info!
Old Jan 13, 2004 | 02:37 PM
AVATAR's Avatar
interesting . . .
Old Jan 13, 2004 | 03:14 PM
gdrum's Avatar
Default Re: Turbo Heat sheilds (AVATAR)
woudl this be worth getting? any gains?
Old Jan 13, 2004 | 03:18 PM
Silverbeast's Avatar
Bump for a reply from someone that has used one.
Old Jan 13, 2004 | 03:22 PM
Default Re: (HoustonSi)
http://www.twinsturbo.com
They sell them, but the prices is ~$325
Old Jan 13, 2004 | 03:57 PM
twkdCD595's Avatar
Default Re: (olsonjus)
A guy around here runs those on his rx7 upgraded twins. Seems to help keep the heat in for a bit better responce and spool he says.
Old Jan 13, 2004 | 05:18 PM
Quad-Damag's Avatar
Default Re: (twkdCD595)
wouldn't that leave all the heat inside the turbo and cook it up?
I was going to get the one they sell at summit racing, where it raps the whole turbo, but i herd it keeps all the heat inside and kills the life of the turbo
they are like 68 bucks at summit racing
Old Jan 13, 2004 | 05:43 PM
FredoSP's Avatar
interesting, but I don't know about spending that kind of $. As long as your A/C lines or hoses are wrapped with some sort of thermal tape you should be fine.
Old Jan 13, 2004 | 05:53 PM
SIXTYdashONE's Avatar
HT's Biggest Loser
Default Re: Turbo Heat sheilds (FredoSP)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FredoSP &raquo;</TD></TR><TR><TD CLASS="quote">interesting, but I don't know about spending that kind of $. As long as your A/C lines or hoses are wrapped with some sort of thermal tape you should be fine.</TD></TR></TABLE>
It also assists in Spool-up Fred-Ho. not just for ac and stuff.
Old Jan 13, 2004 | 08:49 PM
twkdCD595's Avatar
Default Re: Turbo Heat sheilds (SIXTYdashONE)
the more expensive atp units are actually made out of high end metals like inconnel, stainless, aluminum.... and whatnot other materials, so they are very expensive.
the ones that bag the whole turbo and other designs are made more of a conventional material... less expensive to manufacturer and sell.
Old Jan 13, 2004 | 09:15 PM
calib17a's Avatar
Check this one out. Alot nicer for only $74 polished and $59 not.
This ones from http://www.atpturbo.com
Modified by calib17a at 10:40 PM 1/13/2004
Old Jan 13, 2004 | 09:28 PM
pornstarSR's Avatar
Default Re: Turbo Heat sheilds (calib17a)
the idea behind it is this
the heat and energy from the combustion process is what drive the turbo..
keeping the heat in the housings and the manifolds will greatly increase the amount of energy getting to the turbo....
i dont beleive it lessesn the life of the turbo....but who knows
plus i havent run one of these
Old Jan 13, 2004 | 10:43 PM
lazerus's Avatar
Default Re: Turbo Heat sheilds (pornstarSR)
they should make them out of gold
Old Jan 13, 2004 | 11:11 PM
Retired's Avatar
WEST COAST
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by olsonjus &raquo;</TD></TR><TR><TD CLASS="quote">Anyone try these shields from advanced thermal products?
http://www.atpwrap.com/</TD></TR></TABLE>
I like those very much do I hear a special coming along I will contact them in the morning thanks
Old Jan 14, 2004 | 05:46 AM
mike1114's Avatar
Default Re: Turbo Heat sheilds (SPARK RACING INC.)
I've heard that some materials retain moisture from car being parked outside overnight and tend to promote rusting and what not?
But I do like an all metal idea for a heatshield.
Old Mar 3, 2004 | 04:38 PM
Muckman's Avatar
Moderator in Chief
Default Re: Turbo Heat sheilds (mike1114)
Is there any proof that turbine heat shields/wrap shorten the life of aftermarket turbo bearings?
Old Mar 3, 2004 | 05:39 PM
5STAR3's Avatar
Default Re: Turbo Heat sheilds (lazerus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lazerus &raquo;</TD></TR><TR><TD CLASS="quote">they should make them out of gold</TD></TR></TABLE>
mos def gang-stah
HT Chaplain
Jun 18, 2009 06:01 AM
discrete
Nov 13, 2005 02:16 PM
wade
Aug 21, 2005 04:26 PM
2manycars2choose
Oct 12, 2003 02:57 PM
3vilMonkey!
Jul 31, 2003 08:50 PM
