OT: Lug nuts came loose
Old Jan 13, 2004 | 02:09 PM
Denny's Avatar
Default OT: Lug nuts came loose
i was driving to school and my rear driverside lug nuts came loose. on me. my question is, will i have done any damage to the car, rotors,etc..? i drove about 20 miles like this. i thought it was just my OEM jack bumping around. thanks
Old Jan 13, 2004 | 02:14 PM
DC2fanboy's Avatar
Default Re: OT: Lug nuts came loose (Denny)
All 5?!?
How loose were they?
But if you could drive on it reasonably, probably wasn't that bad...
Denny's Avatar
Default Re: OT: Lug nuts came loose (DC2fanboy)
3 of them!
Old Jan 13, 2004 | 02:51 PM
nightrider's Avatar
i think you should be fine if you weren't going excessively fast. i do suggest however investing in a torque wrench.
Old Jan 13, 2004 | 02:54 PM
Mike M's Avatar
Founding Member
Stock Lugs and Stock Rims?
Old Jan 13, 2004 | 03:01 PM
Cosworth's Avatar
I dunno, it depends on how fast you were driving in that 20 min. It's more than likely nothing, but if it was thumping then who knows... highly unlikely, may have slightly bent some studs, possibly the spindle, etc. I would torque back the lugs and keep an eye on it for the next few days. Probably nothing though.
Old Jan 13, 2004 | 03:05 PM
TeamNextGenChris's Avatar
i'd pull the wheel off and make sure it didn't damage the threads or bend any of the studs while it was banging around.if all looks good,i'd throw the wheel back on and torque them properly.as said above-a torque wrench is a good investment.
were they stock lugs?
chris
Old Jan 13, 2004 | 03:16 PM
jetydosa's Avatar
25 Year Member
You werent the guy last week that was insisting he could use his tapered lugs with the stock wheels were you?
Old Jan 13, 2004 | 03:25 PM
rated_r's Avatar
u will be fine...... Is there a change someone was a beef with u... They could have losend the lug nuts
Old Jan 13, 2004 | 03:48 PM
TypeR 599's Avatar
Default Re: OT: Lug nuts came loose (rated_r)
He has gorilla nuts on 5zigen div3 wheels.
Old Jan 13, 2004 | 05:45 PM
jaa1311's Avatar
Default Re: OT: Lug nuts came loose (Jetydosa)
that was me asking wondering what the diff in lugs were
Old Jan 13, 2004 | 06:00 PM
Denny's Avatar
Default Re: OT: Lug nuts came loose (jaa1311)
i just retorqued my lug nuts. theres 2 small 2mm gashes on the hub part of the rotor. hope everything is okay. im worried and paranoid now
Old Jan 13, 2004 | 08:02 PM
mstewar's Avatar
just keep an eye on it.. check them every couple days.. after you torqued everything and drove it, did you hear any sounds, feel any vibrations, etc? if not, everything is probably ok..
Old Jan 13, 2004 | 08:25 PM
Bbasso's Avatar
Default Re: OT: Lug nuts came loose (mstewar)
Just put some loctite on the threads of the lug bolts, that will stop them from backing off
Old Jan 13, 2004 | 08:41 PM
Warren's Avatar
Wrong-Way Wang
Default Re: OT: Lug nuts came loose (Bbasso)
Not a great idea. Use antiseize and torque properly.
Remove any paint or powder coating on the seating area of the wheel.
Warren
Old Jan 13, 2004 | 09:21 PM
Denny's Avatar
Default Re: OT: Lug nuts came loose (Warren)
everything seems fine. no weird sounds. lugs arent bent and the thread is still good. im just paranoid that i fuged it up.
Old Jan 13, 2004 | 09:38 PM
Bbasso's Avatar
I know...
Old Jan 13, 2004 | 09:59 PM
epy's Avatar
epy
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Warren &raquo;</TD></TR><TR><TD CLASS="quote">Not a great idea. Use antiseize and torque properly.
Warren</TD></TR></TABLE> good post
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Denny &raquo;</TD></TR><TR><TD CLASS="quote">everything seems fine. no weird sounds. lugs arent bent and the thread is still good. im just paranoid that i fuged it up. </TD></TR></TABLE>
no rotor damage? You good to go then.
Old Jan 13, 2004 | 10:49 PM
Denny's Avatar
Default Re: OT: Lug nuts came loose (epy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by epy &raquo;</TD></TR><TR><TD CLASS="quote"> good post
no rotor damage? You good to go then.</TD></TR></TABLE>
theres 2 small 2mm knicks on the hub part, but not the actual surface of the rotor.
Old Jan 13, 2004 | 11:34 PM
JDM TypeR 307's Avatar
Default Re: OT: Lug nuts came loose (TypeR 599)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TypeR 599 &raquo;</TD></TR><TR><TD CLASS="quote">He has gorilla nuts on 5zigen div3 wheels.</TD></TR></TABLE>
nice one ricer One day he might learn not to be one
Get Comptech High Strength Wheel Studs, 2.5" long (set of 4) Those are BUFF as me...
mnbvcxz358
Jul 20, 2010 10:56 AM
HCivExoo
Jan 18, 2009 06:36 AM
nsxtasy
Aug 27, 2008 10:45 AM
integraautox
May 16, 2006 10:04 AM
itr1244
Jul 20, 2002 08:58 PM
