Need help on installing a tach in a 93 civic!
Old Sep 29, 2001 | 12:24 PM
nkSi's Avatar
New User
Default Need help on installing a tach in a 93 civic!
My wires arent labeled tach etc... dunno how to instal my tach for my 93 DX.
Old Sep 29, 2001 | 01:19 PM
92CivicSiR's Avatar
New User
Default Re: Need help on installing a tach in a 93 civic! (nkSi)
What wires are you talking about? Are you talking about the wires on the car, or the wires coming out of the tach? If you are talking about the ones from the tack then:
Red = 12V+ Switched
Black = Ground
I think there is a green wire, and something else. If there is a green wire then I'm pretty sure that one is for the tach signal wire from the dist. then the other on will be your illumination wire. If you go under your hood, ground the black wire and start touching the other ones to the red post on the battery you will be able to figure out thich one is for the lights.
I hope this helps you out a little bit, if you have any more questions, IM me and I'll help you out more.
Old Sep 29, 2001 | 08:17 PM
nkSi's Avatar
New User
Default Re: Need help on installing a tach in a 93 civic! (92CivicSiR)
Im not sure which dist. wire to hook the green one to.
Old Sep 30, 2001 | 01:30 AM
dj_fixx's Avatar
New User
Blue wire on the dist plug (ck)
Or pull the whole dash panel(held in by clips + 2 screws on top of plastic pointing up) then pull the gauges (4 screws) same blue wire, plus your close to the parking lights (I mostly drive fast at night so I like my gauges lit, how bout you)
Test: using A multi meter ah **** it the only other blue wire has a white stripe on it , so im sure you'll find the right wire.
Have fun...
Old Sep 30, 2001 | 04:45 AM
92CivicSiR's Avatar
New User
Default Re: Need help on installing a tach in a 93 civic! (dj_fixx)
Correct. use the blue wire. I would say tap into this wire right behind the gauge cluster so that you don't have to run a wire all the way through your engine bay. The first time I installed my tach I ran it thgough the engine bay, and it looked like ****. I then relocated it to the gauge cluster and got rid of all that loose wire I ran under the hood and it looks soooo much better now.
Old Sep 30, 2001 | 09:47 AM
nkSi's Avatar
New User
Thx guys, very helpful
danielfleenor
Nov 26, 2009 02:29 PM
slimjimdanny
Jan 31, 2007 07:35 PM
93AcuraIntegraGSR
Jan 21, 2007 03:02 PM
purple98ek
Jun 6, 2005 07:57 PM
poppycock2
Mar 16, 2004 04:45 PM
