What turbo should I buy?
Old Jan 13, 2004 | 11:02 AM
tslag's Avatar
Default What turbo should I buy?
I have a 99 Civic SI with
b16a2
9:1 srp
eagle rods
ss valves
balenced and polished crank
blockguard
hondata s100b
drag turbo kit
drag manifold
My turbonetics turbo from the drag kit is leaking oil and I am smoking a little. I think the seals are bad in my turbo. I have 15k miles on it. I want quicker spool and better efficiency. What should I buy. I am running 11 psi but eventually want to run 13 with new injectors. Thanks,
Troy
Here are pics of what the turbo was doing
https://honda-tech.com/zerothread?id=732140
Modified by tslag at 8:46 PM 1/13/2004
Old Jan 13, 2004 | 11:47 AM
tslag's Avatar
Default Re: What turbo should I buy? (tslag)
If you have any to sell let me know.
Old Jan 13, 2004 | 11:56 AM
kevinoneill's Avatar
I'm sure its obvious to you that to get rid of lag, getting a smaller turbo is usually the way to go about it. I'd suggest a T3 or T3/T4, I'm not the most knowledgable turbo person, but maybe we can get some feed back here.
Check out Turbonetics...
There's also, i might ahve this wrong, but there's a T25? i think, its one of the smaller turbo's produced.
And just to clear up, when you say more effecient? you mean turbo effeciency? or fuel effeciency?
Hey good luck, hope we can spike some interest in the turbo savvy's around here.
Old Jan 13, 2004 | 12:21 PM
aka010010
Guest
Posts: n/a
precision
Old Jan 13, 2004 | 12:30 PM
Default Re: (aka010010)
Lots of info there. lol.
Precision makes their own housing, but i believe its still the T3/T4 compressors. I think you should be looking for turbo's with A/R's down in the .43 range. I think it comes down to the smaller your exhaust A/R is the less lag you'll see.
Do you have any specs on your current turbo?
Old Jan 13, 2004 | 12:31 PM
Default Re: (issues4)
Precision
Did no one notice my turbonetics link went to a precision page? sheeshh....
Modified by issues4 at 4:54 PM 1/13/2004
Old Jan 13, 2004 | 12:45 PM
tslag's Avatar
I meant turbo efficiency. I heard that the turbo that comes with the drag kit isn't very efficient at boost levels < 12psi. I know I will have some lag especially with my drag mani but would a ball bearing turbo spool quicker? I was thinking of precision sc50 or sc32. I want around 320 whp. I am not sure what the specs of my current turbo are.
Old Jan 14, 2004 | 12:09 AM
tslag's Avatar
Default Re: (tslag)
nobody has any suggestions?
Old Jan 14, 2004 | 06:17 AM
Beanbooger's Avatar
Default Re: (tslag)
GT28RS would give the best performance, efficiency, and spool of any turbo on the market.
Old Jan 14, 2004 | 07:58 AM
phiberoptik's Avatar
you want a quicker spool and better efficiency... well precision has some very nice turbos. For the boost you want to run, look for something like a 57 trim with a .48 a/r to help with spool. Still can make good power with a faster spool.
Old Jan 14, 2004 | 09:19 AM
tslag's Avatar
Default Re: What turbo should I buy? (phiberoptik)
anyone else?
Old Jan 14, 2004 | 10:20 AM
Kataku2K3's Avatar
The GT's are definately a nice series (we've had 2 sets on the Supra (GT-30R's, 35R's) and those things spool like crazy, even after you shut down the motor )... I woulld stick to Precision but if you're looking for something roughly in the same size and a little cheaper go down to the SC's, possibly a SC-50 or something along those lines... Just my $0.02, Good Luck
Old Jan 14, 2004 | 12:57 PM
-Trinitron-'s Avatar
After using many flow calculators and reviewing compressor maps for about a month now, a really good trim for the b16 is a T3/T04e .54 trim with a .63 A/R. The .54 is at 75%+ efficiency all the way through 16 psi. If you are looking for bigger numbers and a quicker spool I would go with a .60 trim with a .48 A/R, T3/T04e Just my .02 ...good luck though.
Old Jan 14, 2004 | 01:12 PM
Egg-weezy's Avatar
14B, DSM turbo. Spool->very quick. Efficiency->not that great.
TurboTeG4
Jan 21, 2006 07:39 PM
Type-GS-R-Turbo
Dec 31, 2004 08:29 AM
fl_hmong_racer
Oct 7, 2004 12:52 PM
DC2 BoZz
12
Sep 25, 2004 06:39 PM
