Removing steering wheel mounted cruise control 2-button module on 97?
Old Jan 13, 2004 | 10:11 AM
vabchaccord's Avatar
Default Removing steering wheel mounted cruise control 2-button module on 97?
One of the buttons is sticking, probably due to a drink getting spilled in it. I wanted to remove it to clean the inside of it, but see no screws or fastening devices. How do I get it off? HELP!!!!!!!!
Old Jan 13, 2004 | 12:10 PM
accordguy96's Avatar
Default Re: Removing steering wheel mounted cruise control 2-button module on 97? (vabchaccord)
You have to remove the cruise control box cover. You will see a little seam/slot, stick a flathead screw driver in it and it pry's off. You'll think it'll break since it's on there tight but you won't. Once that's popped off there are two small screws inside of it and a wiring harness you can unplug.
erikiksaz1
Jan 21, 2007 05:56 PM
GsRiNtEeGrA14
Feb 26, 2006 10:43 AM
CivilizedCiv
May 11, 2003 12:33 PM
jabroni95gsr
Nov 27, 2002 11:52 PM
ArchAngel Sabastian
Oct 25, 2002 04:40 PM
