Post your SC34 Dyno! and anything else you want.
Old Jan 13, 2004 | 09:52 AM
1SlowSi's Avatar
Default Post your SC34 Dyno! and anything else you want.
Just wanted to see what kinda number you guys are seeing with the SC34? Boost, Whp, torque, hell even throw in your C/R and on what motor. I dont know whether to get the SC61 or SC34. Thanks for the help!
Old Jan 13, 2004 | 10:11 AM
B18bEK's Avatar
hybridcivicls-t made 264hp @ 11psi on the SC34 .. his car is pretty quick
Old Jan 14, 2004 | 10:29 PM
Reilly's Avatar
Default Re: Post your SC34 Dyno! and anything else you want. (1SlowSi)
see sig........
BTW, I am running a couple more pounds of boost since my dyno, so?
P.S. Hey
Modified by Reilly at 7:41 AM 1/15/2004
Old Mar 31, 2004 | 10:27 PM
1SlowSi's Avatar
bump
Old Apr 11, 2004 | 01:38 PM
rextec's Avatar
bump!!
Old Apr 11, 2004 | 01:45 PM
Evil DOHC's Avatar
Default Re: Post your SC34 Dyno! and anything else you want. (rextec)
Just ran an ls I built with a revhard kit. 11 psi, ran 12.6 @ 110 on street tires in a bubble. The turbo is pretty, nice but not my favorite out of the SC family. I would def stick with the SC61 if I was building something from scratch.
EVIL
Old Apr 11, 2004 | 08:45 PM
1SlowSi's Avatar
Default Re: Post your SC34 Dyno! and anything else you want. (Evil DOHC)
Well if im only wanting to make 400 or so, then the SC34 should be fine. Because it would be a watse of a turbo running an SC61 no more than that. Thats a waste of another 150-200whp. Plus i only wanna run like 8-10psi daily, and maybe 15+ for fun. At low boost with the Sc61, thats not even workin that thing! Thats just my thought on that. I WAS gonna go with the SC61 till my goals changed. Basically, im never gonna run at the track, and anything only 400whp on the streets is useless... from what ive seen!
Does anyone have any numbers they made on the 34?
Old Apr 11, 2004 | 08:48 PM
TheShodan's Avatar
Moderator
We just did a B18C1 with a combination of SC34 and SC44 w/ a slightly smaller trim turbine setup. At 8psi he was at 261whp@174ft/lbs of torque. I was just as suprised as other people at the dyno, and I created the turbo specs. Very efficient for 8-10 psi daily.
Old Apr 12, 2004 | 05:49 AM
1SlowSi's Avatar
Default Re: (TheShodan)
So you think this thing will pull out 400whp on pump? SC34 that is.
Old Apr 14, 2004 | 12:39 AM
Ty.'s Avatar
Ty.
Default Re: (1SlowSi)
with my sc34 i got 260 whp and 189 TQ on 8.7 psi!
Old Apr 14, 2004 | 01:56 AM
1SlowSi's Avatar
Default Re: (BLACKEG2)
On what motor? whats your setup?
Old Apr 14, 2004 | 04:07 AM
Arturbo's Avatar
Better than steak
25 Year Member
277whp/ 200ft.lbs at 8psi Gsr completely stock engine.
Old Apr 14, 2004 | 04:41 AM
1SlowSi's Avatar
Default Re: (Arturbo)
Well that sounds good to me. So 300whp @10 psi would be ideal. and 400 should be too on pump. MAYBE! Hey Art, what was this setup? exhaust wise.
Old Apr 14, 2004 | 12:29 PM
Ty.'s Avatar
Ty.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1SlowSi &raquo;</TD></TR><TR><TD CLASS="quote">On what motor? whats your setup?</TD></TR></TABLE>
stock b16a3 and hondata
Old Apr 14, 2004 | 08:46 PM
Arturbo's Avatar
Better than steak
25 Year Member
2.5" - 3" flared downpipe 3" thermal. I had a freak motor.
Old Apr 14, 2004 | 09:19 PM
1SlowSi's Avatar
Yeah i guess you do!
Old Apr 14, 2004 | 10:15 PM
quik sol's Avatar
Where can you buy an SC34, I can't find one...
Old Apr 14, 2004 | 10:46 PM
hulkhb's Avatar
Default Re: (quik sol)
I am sure Arturbo can help you there
Old Apr 15, 2004 | 04:40 AM
quikB18B's Avatar
Default Re: (hulkhb)
I made 271/253 on a conservative tune, @ 1 bar, Sc34, Ls motor, 3" exhuast
A friend of mine with similar setup made 302/25x on like 15-16 psi, Ls motor, sc34 same tuner, different dyno, same weekend as me.
Old Apr 15, 2004 | 07:29 AM
G
sh!t happens.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1SlowSi &raquo;</TD></TR><TR><TD CLASS="quote">Yeah i guess you do!</TD></TR></TABLE>
yo anthony the sc34 is good for the power u are wanting.... u change your damn mind to much....hahahhaha.... u need to get back to that red si its lonely... hit me up later....
sc34
JDM_Risa
Oct 7, 2005 01:03 PM
sleepin91teg
Aug 1, 2004 07:42 PM
29psiHybrid
Apr 1, 2003 11:45 AM
Javier23
Mar 18, 2003 03:59 AM
TypeC
Mar 26, 2002 04:25 PM
