High-Flow cat & OBD2
Hey, I just recently put on a new cat and because its just a straight pipe its throwing a O2 code. I know that there is nothing that I can do to get the check engine light to go away with this setup, but my question is ... I was told that since the sensor is not reading a 100 degree difference between the 2 sensors it's telling the ECU that I'm running lean ... and dumps more gas in. Is this true?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 971ud3 »</TD></TR><TR><TD CLASS="quote">Hey, I just recently put on a new cat and because its just a straight pipe its throwing a O2 code. I know that there is nothing that I can do to get the check engine light to go away with this setup, but my question is ... I was told that since the sensor is not reading a 100 degree difference between the 2 sensors it's telling the ECU that I'm running lean ... and dumps more gas in. Is this true?</TD></TR></TABLE>
The secondary O2 sensor isn't used to determine fueling, so I would doubt that its absence would switch the ecu into open loop.
Sure you can do something about the CEL. You can:
1. http://www.importparts.com/imp...CG-28
2. http://www.ntpog.org/mods/fifth-afc/ecu.shtml
3. http://www.mileliminators.com/
4. do something similar to this: https://honda-tech.com/zerothread?id=221347
5. get a real high flow cat to replace the test pipe you installed.
6. reinstall your stock cat.
Extremity
Apr 29, 2006 08:29 AM
D3U1LT
Sep 20, 2004 05:24 AM
