type R rear sway bar on an EK hb .?
Old Sep 28, 2001 | 10:09 PM
GokuSSJ4's Avatar
Default type R rear sway bar on an EK hb .?
i was told that if i use gsr control arms , im able to bolt in a type R sway bar .does any one know if it works ? since the gsr control arms sits the same way then the stock 98 hb control arm , need help ?
Old Sep 29, 2001 | 05:50 AM
DragII's Avatar
Default Re: type R rear sway bar on an EK hb .? (Spoon1)
I doubt it being that the type r sway bar does NOT bolt up to a gsr
Old Sep 30, 2001 | 12:28 AM
GokuSSJ4's Avatar
a friend of mine had a gsr and he had the itr sway bar , so has any one done it on the ek hb
Old Sep 30, 2001 | 06:12 AM
DragII's Avatar
it'll work, but there is some drilling involved
Old Sep 30, 2001 | 09:07 AM
siisgood00's Avatar
New User
may I suggest a bar that FITS YOUR CAR!!
Old Sep 30, 2001 | 09:36 AM
bigTom's Avatar
Default Re: type R rear sway bar on an EK hb .? (siisgood00)
hey buddy... get the stick out of your ***
Old Sep 30, 2001 | 03:11 PM
siisgood00's Avatar
New User
Default Re: type R rear sway bar on an EK hb .? (ek9t)
how does that mean i have a stick up my *** suggesting a bar that actually fits. It is alot of hassle and money to get an ITR bar to fit any car other than an ITR, not to mention it dosent fit and there are so many cases of the bar pulling out. I know someone who had a GSR and his ITR bar pulled out. Some of this is covered here too. https://honda-tech.com/zerothread?&i...=569484#569484
I could also post all the links to complaints about the ITR bar pulling out of non-ITR cars but that would take a tad too much time.
Old Sep 30, 2001 | 04:15 PM
bigTom's Avatar
put it on correctly and it will be fine... if u put it on not knowing what u are doing it will rip out... as for making things fit... who wants to just bolt **** up? half the fun is making something fit!
Old Sep 30, 2001 | 06:40 PM
il8apex's Avatar
New User
Back off on the flame, ek9t...
As for the bar, save yourself some headache and just get a Progress 22mm rear bar. It mounts perfectly with no fiddling and lessens the chance of tearout by mounting the brackets through the lower shock mounts. No drilling, no mess, perfectly neutral handling afterward.
-T
Old Oct 1, 2001 | 12:39 PM
Petah's Avatar
Default Re: type R rear sway bar on an EK hb .? (il8apex)
In order to bolt an R sway bar into your EK civic, the only control arm you can use is yours. There are already holes drilled out for endlinks. You will use the end links for a SI coupe, D-brackets and bushings of an ITR, and redrill the subframe to accomodate the lager D-bracket. Remember you have to reinforce the cross member so that the bar won't come flying off during a high speed corner. You can check out the links for more info. Hope this helps.
http://patriot.net/~merritt/tech.html
http://hybrid.honda-perf.org/tech/ITRon6G.html
Old Oct 1, 2001 | 07:24 PM
slow_civic's Avatar
Default Re: type R rear sway bar on an EK hb .? (eg-six)
i'd suggest an alternate source for endlinks. i called honda for a price on endlinks with associated hardware and they quoted me somewhere around $250. this isn't a joke.
Old Oct 2, 2001 | 12:24 AM
GokuSSJ4's Avatar
Default Re: type R rear sway bar on an EK hb .? (slow_civic)
what about the comptech rear sway bar , will it bolt up ?. i know that it bolts right own an SI and im able to used and Si rear sway bar ,but will it be to much for the hb
kulo
Suspension & Brakes
20
Jan 25, 2009 10:02 PM
SaYjAiBaO
Oct 26, 2006 05:58 PM
crxsiperf
Mar 26, 2006 05:30 PM
navin
Oct 29, 2002 05:04 PM
mamaboy
Nov 17, 2001 06:49 AM
