z6 pistons?
Old Jan 12, 2004 | 06:14 PM
static_signal's Avatar
Default z6 pistons?
Whats the best pistons to use in a z6 block ... ???
Old Jan 12, 2004 | 06:25 PM
VTECVillain's Avatar
Default Re: z6 pistons? (static_signal)
What's your goals/needs? High compression N/A? Low compression with boost? Aftermarket? OEM? JDM? Pistons are available in wide varieties, it just depends on what you're wanting to do and how much you are willing to spend?
Old Jan 13, 2004 | 05:03 AM
Default Re: z6 pistons? (VTECVillain)
high comp. all motor.... i thought about boring it to 84mm..
Old Jan 13, 2004 | 03:13 PM
civicsitek GanGsTa's Avatar
d16a1 pistons for a oem high compression option.
Old Jan 13, 2004 | 05:04 PM
1BadDC2's Avatar
Default Re: z6 pistons? (civicsitek GanGsTa)
what about oem for low comp / turbo.
d-series-buildup
Dec 23, 2007 09:22 AM
redlude94
Oct 14, 2005 03:33 PM
ls_vtec_crx
Apr 3, 2004 04:43 AM
TiggsCRX
Mar 24, 2004 08:14 AM
Renegade
Mar 2, 2004 12:36 AM
