will a y7 tranny fit on a z6?
Learn this, know this, live this,
ANY D-series tranny will work with ANY D-seires engine. Period.
Just gotta worry about the clutch.
Same goes for B-series if you're wondering.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4crx4me »</TD></TR><TR><TD CLASS="quote">ANY D-series tranny will work with ANY D-seires engine. Period.</TD></TR></TABLE>
With the exception of the DOHC D16A1 Integra tranny and the pre 88 D series tranny's
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">Same goes for B-series if you're wondering.</TD></TR></TABLE>
With the exception of the DOHC B20A/B21A Prelude trannys.
Basically all 88-00 SOHC D series and the DOHC ZC trannys will fit.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECVillain »</TD></TR><TR><TD CLASS="quote">
Basically all 88-00 SOHC D series and the DOHC ZC trannys will fit.</TD></TR></TABLE>
Sorry about that, I assumed the D16A1 was similar to the ZC tranny, I learn somthing everyday on HT
But for knowledge sake, what makes them incompatible, Villain?
The D16A1 is similar in appearance to a ZC but its from the 1G Integra. You can swap these into a 3G Civic/CRX since it uses the same mounting points. Although the D16A1 is a D series and the 3G Civic/CRX use a D series, their motors and trannys are not compatible to mount in the 88+ models. The D16A1 tranny will come close to bolting up, a few holes are off - one at the bottom and one at the starter if I remember correctly. The upper mount point will not line up to the frame rail bracket and there's no OEM mount that you can switch to for it to work.
92EGK20
Nov 12, 2007 07:49 AM
da_rimrocka
Apr 19, 2006 11:37 PM
