Charge pipes....
OK,
heres the deal. I am trying to figure out what size charge piping to run with my greddy sohc kit. It came with 2 inch from the turbo and then it switches into
2 1/4 before it goes into the throttle body. Now this is for the set up non intercooled, however I bought a intercooler with inlets and outlets that are 2 1/2 inches. Should I just run it like this - from turbo 2inch then use a reducer to 2 1/2 into the intercooler and then use another reducer to go out from the IC 2 1/2 into the 2 1/4 pipe? Or should I just upgrade all the to a larger size, if so what size should I go to?
