Thought I would share some pic's I made today.... TURBO related...:)
Banned
InlinePro T3 Exhaust Manifold
CP 81mm 9:1 Pistons for B16a2
I was bored so I thought I would share, These are part of my Turbo Project on my 99 Si...
Waiting on my Precision SC61, and a lot of other parts as well, My goal is to hit somewhere around 380-400 whp and around 250-260ft-lbs of torque. Track use of course.
Setup:
Precision SC61
Precision Injectors
InlinePro T3 Manifold
JG victor X manifold
Tail 38mm wastegate
Tail 50mm BOV
CP 81mm Forged Pistons
Eagle H-beam Rods
ARP rod bolts
ARP head studs
Full Supertech Valve Train Valves/Retainers/springs
Stock B16 Cams
Custom Intercooler piping
Custom full 3" DP
Thermal 3" exhaust
AEM EMS
Walbro fuel pump
fuel regulator
Quaiffe LSD
Tilton twin disk clutch/flywheel
Gauges ext...
Modified by Irishweird00 at 3:53 PM 1/12/2004
Modified by Irishweird00 at 4:00 PM 1/12/2004
Modified by Irishweird00 at 5:59 PM 1/12/2004
Setup:
Precision SC61
Precision Injectors
Tail 38mm wastegate
Tail 50mm BOV
Eagle H-beam Rods
ARP rod bolts
ARP head studs
Stock B16 Cams
Custom full 3" DP
Thermal 3" exhaust
AEM EMS
Walbro fuel pump
fuel regulator
Quaiffe LSD
Gauges ext...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hoodwinked »</TD></TR><TR><TD CLASS="quote">what compression ratio do those pistons yield?</TD></TR></TABLE>
In a B16A, that piston @ 81mm would be about 9:1 CR
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snoochtodanooch »</TD></TR><TR><TD CLASS="quote">those pistons look sweeet. I am tempted to get the turbo pistons for my d16 but i am low on cash. I think its almost time to cash out my stocks for some BOOST.</TD></TR></TABLE>
you can cash one out for me
I need some more cash to finish this baby!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Unsung EM1 »</TD></TR><TR><TD CLASS="quote">The battle of the EM1's.
I'll show you who's boss - I bet I'll blow my engine first.
I wanna play
Nice setup .. so far all i have for my EM1 is a Full-Race T3/60-1
</TD></TR></TABLE>I wanna play
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Scott - 93HB Si »</TD></TR><TR><TD CLASS="quote">
hehe i have those
but i plan to add an inlinepro 3mm headgasket tp ;pwer ot dpwm tp 9.6:1
hehe i have those
your setup is almost just like mine except mine is for a street car! good luck and let us know how it turns out.
MY Setup:
Precision SC61
Precision Injectors
Tail 38mm wastegate
HKS SSQ BOV
SRP 81mm Forged Pistons
Eagle H-beam Rods
ARP rod bolts
ARP head studs
Stock B16 Cams
Custom full 3" DP
Hondata
Walbro fuel pump
Quaiffe LSD
Clutch Masters clutch
Gauges ext...
to you and me for pretty decent setups
MY Setup:
Precision SC61
Precision Injectors
Tail 38mm wastegate
HKS SSQ BOV
Eagle H-beam Rods
ARP rod bolts
ARP head studs
Stock B16 Cams
Custom full 3" DP
Hondata
Walbro fuel pump
Quaiffe LSD
Gauges ext...
Can i battle in the EM1 class too?
</TD></TR></TABLE>Can i battle in the EM1 class too?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Irishweird00 »</TD></TR><TR><TD CLASS="quote">9:1
The only other CP pistons that are stock 81mm specs are 10:5:1</TD></TR></TABLE>Those are not 9-1 pistons in the pix. They are the 9.8-1's
