GSR rear Sway bar on ek
Old Jan 12, 2004 | 07:16 AM
jimmhatch's Avatar
Default GSR rear Sway bar on ek
what is the size of the 94-00 GSR rear swaybar? which Is bigger? the 99-00Si rear swaybar or 94-00 GSR rear swaybar ?
Old Jan 12, 2004 | 08:29 AM
ill phil's Avatar
Default Re: GSR rear Sway bar on ek (jimmhatch)
I thought they were the same- 14mm.
Old Jan 12, 2004 | 09:06 AM
wdskuk's Avatar
gsr is bigger.
GSR - 14m
SI - 13mm
Old Jan 13, 2004 | 08:28 AM
jr_istheman's Avatar
Default Re: (wdskuk)
if anyone is interested, I have a GSR rear swaybar for sale, for just 50$. hit me up if interested and yes, it is 14mm.
Old Jan 13, 2004 | 09:00 AM
the redsquare forecast's Avatar
Default Re: (jr_istheman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jr_istheman &raquo;</TD></TR><TR><TD CLASS="quote">hit me up if interested and yes, it is 14mm. </TD></TR></TABLE>
Which is 22mm then?
Old Jan 13, 2004 | 09:08 AM
boostng r's Avatar
a
Default Re: (One Term President)
maybe aftermarket
Old Jan 13, 2004 | 09:18 AM
sohc_boy's Avatar
22 is itr.
Old Jan 13, 2004 | 10:15 AM
wdskuk's Avatar
yup itr is 22mm
Old Jan 13, 2004 | 11:09 AM
cre18's Avatar
if your thinking about getting a rear sway bar for your ek, i'd recommend the beaks kit swap
http://www.beaksproducts.com/main.html
SRK-EK
Developed with the same theory as the proven SRK-EG, Beaks Products' SRK-EK (subframe reinforcement kit) minimizes the chance of subframe "tear-out" often experienced with oversized anti-sway bar upgrades. Due to the thin construction of the subframe and insufficient factory reinforcements, the subframe sheet metal shears under extreme twisting of the anti-sway bar. The results are severe damage and expensive repairs. The SRK-EK reinforces the subframe from both inside and outside, distributing forces over a greater area of contact. This reduces the shear stress and effectively prevents sheet metal failures.
Parts Included
6061-T6 Aluminum Support Plates
6061-T6 Aluminum Nut Plates
Zinc Plated Grade-5 Bushing Bracket Flange Bolts
Zinc Plated Bushing Bracket Flat Washers
Metal Endlink Collars
Metal Endlink Washers
Installation Instructions
Additional Parts Required
(Must purchase separately from Acura for complete ITR rear anti-sway bar setup)
P/N 52300-ST7-Z01 Integra Type-R Rear Stabilizer Bar (Qty. 1)
P/N 52315-ST7-Z01 Anti-sway Bar Bushing (Qty. 2*)
P/N 52308-SS0-000 Bushing Bracket (Qty. 2*)
P/N 52320-S04-003 '99-'00 Honda Civic Si Rear Stabilizer Endlink Assy., RH (Qty. 1)
P/N 52321-S04-003 '99-'00 Honda Civic Si Rear Stabilizer Endlink Assy., LH (Qty. 1)
Applications
All non-ABS equipped models of the following:
'96-'00 Honda Civic
Compatible with most aftermarket lower tie-bars!!!
Old Jan 13, 2004 | 11:11 AM
pdiggitydogg's Avatar
Im either going to get the oe si bar
or ***** out comptech combo
Old Jan 13, 2004 | 11:30 AM
=GAME='s Avatar
Default Re: (pdiggitydogg)
comptech.
Old Jan 13, 2004 | 12:26 PM
SkyeC's Avatar
Boba Connoisseur
25 Year Member
Default Re: (O.G triple O.G)
IMO, either go with a 13 or 14mm rear bar and stock mounting hardware OR get a Comptech 22mm sway/tie kit. No other options.
Old Feb 14, 2004 | 01:06 PM
greebler's Avatar
Default Re: (SkyeC)
Can you use GSR endlinks and a GSR rear sway on a EK? Or do you need the Si endlinks.
Old Feb 14, 2004 | 01:30 PM
ill phil's Avatar
Default Re: (greebler)
I do believe so, btw- I'll be selling my GSR rear sway soon.
Old Feb 15, 2004 | 02:17 PM
tougeEGsies's Avatar
[QUOTE=
"build cars with the same passion that a graffiti artist looks at a bare wall, or a painter looks at a blank canvas. with creativity, individuality, and skill."
[/QUOTE]
super street article
Old Feb 15, 2004 | 02:21 PM
You can pick up a rear sway with all the hardware at a junkyard anywhere
from 25-50 bucks depends on the yard. I got my front and bake off a teg for
like fifty bucks. All the hardware included.
sniggler316
Jul 29, 2006 07:15 PM
EeeJayEight
Apr 7, 2005 07:23 PM
jlamaster
Oct 13, 2003 12:15 PM
killerboots
May 26, 2003 07:55 AM
Kronic
Feb 9, 2003 09:41 PM
