Having trouble removing dash trim to insert EL Gauge
Old Jan 11, 2004 | 09:29 PM
mrb18c's Avatar
Default Having trouble removing dash trim to insert EL Gauge
Hi Guys,
I'm an australian Honda Accord (1995 model) owner having trouble removing the dash trim to insert EL Gauges. I've removed 2 screws underneath the tacho/speedo, and 2 other screws on either side. Half of the dash is coming off, but the section where my climate control doesn't seem to be moving all that much. I don't want to pull to hard as i am affraid of cracking the panel. are there any other screws i havent removed?
the layout is practically the same just opposite sides of each other as i have sourced helpe before for my integra vti-r (gsr) in the past.
All help is much appreciated.
Thanks
Old Jan 11, 2004 | 09:40 PM
The_Todd's Avatar
Farts in the shower
Default Re: Having trouble removing dash trim to insert EL Gauge (mrb18c)
I think there are a couple of screws in the vents (above the climate control) and some by your ashtray/cigarette lighter area.....hope this helps.
Here is a link for a pic to show the screws:
http://www.hondaautomotivepart...RNISH
Old Jan 11, 2004 | 09:55 PM
mrb18c's Avatar
Default Re: Having trouble removing dash trim to insert EL Gauge (VRDrvr)
thanks for that VRDrvr.
I've actually got digital climate control...would you happen to be familar with and screws or mounts there?
i've tried taking those screws out aswell...
Old Jan 13, 2004 | 05:10 AM
typertn's Avatar
i didnt know that there was a digital climate control, but if your dash is made anything like the one in the us, then you should have one two in the actual instrument panel area, then there is one behind the cruise/sun roof button, then another behind the degog, and two under the climate control. after you get that trim piece off, then there are four bolts that actually hold the instrument cluster on. remove those four, and unplug the three connectors at the top and it should come out.
uberEFtuner
Feb 18, 2014 08:26 AM
eggsi619
Nov 7, 2009 07:39 PM
sixfiveoh
Aug 8, 2009 10:43 PM
haitian1
Feb 17, 2006 01:05 PM
