accord rack and pinion question?
Old Jan 11, 2004 | 07:44 PM
DBrown's Avatar
Default accord rack and pinion question?
have a 90 accord, and the steering has started to act funny.
some times it has power and sometimes it feels like it has no power. sometimes when you turn the wheel, the wheels don't turn right off, they hesitate and then turn only part of the way. the assumption is I have a bad rack. has any one had this problem?
also, I can get a rack from a 90 integra for free. will this bolt in?
much thanks to anyone that can help.
Old Jan 11, 2004 | 10:42 PM
Kelly.'s Avatar
I've quit using this account
i dont think the rack from a integra will fit.
as for the problem you might have a bubble in the system. not sure how to fix it though..
how need PS anyway
Old Jan 12, 2004 | 04:22 AM
DBrown's Avatar
Default Re: (llewsirc)
well, this is my wifes DD. so power steering is needed. and the whole thing about the wheel not turning some of the time is scaring the crap out of her. thanks for the input though. anyone else got any ideas?
Old Jan 12, 2004 | 01:30 PM
vc's Avatar
vc
Default Re: (DBrown)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DBrown &raquo;</TD></TR><TR><TD CLASS="quote">well, this is my wifes DD. so power steering is needed. and the whole thing about the wheel not turning some of the time is scaring the crap out of her. thanks for the input though. anyone else got any ideas?</TD></TR></TABLE>
What is DD? Get a JDM steering wheel
Old Jan 12, 2004 | 01:49 PM
Chiovnidca's Avatar
Default Re: accord rack and pinion question? (DBrown)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DBrown &raquo;</TD></TR><TR><TD CLASS="quote"> have a 90 accord, and the steering has started to act funny.
Have you checked the fluid level?
Old Jan 12, 2004 | 03:18 PM
DBrown's Avatar
DD = daily driver
I checked the fluid, that was my first assumption. it was a little low but nothing to be worried about. I have had hondas before but I never had any problems out of the steering. I mainly work on trucks and older cars, on those you rarly have the same kind of systems because of the space that they need for the front wheel drive. is this the typicle symptoms of the rack failing or is it just an indication of another problem I could be over looking?
Old Jan 12, 2004 | 04:04 PM
LookingForVTEC's Avatar
Top off the fluid first. I have a 91 accord that is doing the same thing and I noticed that power steering fluid is leaking from the right and left side of the rack. I let a shop look at it and they said that I need to replace the rack.
Old Jan 14, 2004 | 12:36 PM
JDM_CD7's Avatar
Default Re: (LookingForVTEC)
I'm also having the same Problem with my 5th gen, I replaced the rack with a used one but i'm guessing since I never got the alignment done it screwed something up. Also I its leaking from the drivers side madd.....
Someone HELP US!!!
Checkers
Jan 7, 2019 05:20 PM
TrzystaCek
Jun 18, 2018 01:54 PM
ucd_4_life
Jan 26, 2006 05:36 PM
jinjabred
Jan 7, 2006 07:06 PM
