my friend is painting his wheels.
Old Jan 11, 2004 | 07:27 PM
Rhythm Racer's Avatar
Default my friend is painting his wheels.
whats up guys, my friend wants to paint his wheels this weekend, and since lots of u have painted wheels i thought i'd ask here....here is his plan:
clean wheel really well. 2000 grit sandpaper the hell out of it...to rough it up...or would 1000 grit be better?? then tape off the tire and the lip (he wants to keep the lip silver) and paint it gloss black (5 coats) . then clear coat it (like 3 coats).
any suggestions? tips, hints? paint suggestions? anythign you'd like to add?
thanks
Old Jan 11, 2004 | 07:29 PM
midorigreen.'s Avatar
Default Re: my friend is painting his wheels. (Rhythm Racer)
use index cards between the wheel and tire instead of taping
it saves so much time and works well also
take your time and dont do a half assed job cause you will regret it...
Old Jan 11, 2004 | 07:40 PM
The_Todd's Avatar
Farts in the shower
Default Re: my friend is painting his wheels. (midorigreen.)
Take some b4 and after pics
Old Jan 11, 2004 | 07:43 PM
vtec-izm's Avatar
Default Re: my friend is painting his wheels. (VRDrvr)
make sure u dont touch it too early when its drying, i learned that the hard way
Old Jan 11, 2004 | 07:57 PM
FlaN.'s Avatar
not necessary, but I went so far as to put a plastic tarp over the wet wheels while they were drying so no dust got on em. good luck.
Old Jan 11, 2004 | 08:09 PM
Default Re: (theJUMPoff)
so with the steps he has in mind..they'll come out fine?
what do you suggest for clear coat, we've painted before and the clear coat never really comes out smooth...its always kinda rough.
ill have before and after pics...i must warn you tho..its not a honda
Old Jan 12, 2004 | 09:58 AM
Default Re: (Rhythm Racer)
bump
Old Jan 12, 2004 | 10:03 AM
pyrojeff's Avatar
Even if you do light and even coats, it will still come out somewhat rough. You can always try sanding with an extremely fine grit of sandpaper, or simply waxing the wheels always does the trick.
Old Jan 12, 2004 | 10:08 AM
Default Re: (pyrojeff)
my wheels didnt come out rough..try using the duplicolor wheel clearcoat, it takes awhile to dry, but well worth the outcome
Old Jan 12, 2004 | 07:00 PM
Default Re: (midorigreen.)
thanks for the suggestions everyone...
he got quoted anywhere from $65 (plus shipping) to $125 each wheel to get powdercoated...so spray paint it is
Psychoteen101
Apr 1, 2009 07:14 AM
404S2K
Honda S2000
23
Jul 25, 2007 12:38 AM
JDM-Rota
Aug 9, 2005 01:24 PM
jdmspoonitr
Oct 15, 2003 01:56 PM
Farrell
Apr 21, 2002 06:14 PM
