overclocking stock B16 injectors
Old Jan 11, 2004 | 05:52 PM
b20bvtec'd's Avatar
Default overclocking stock B16 injectors
I have a stock b16a head with gsr cams. I have an aem fpr and fuel rail, it's turned up to about 50 psi and i was wondering is it ok to run these injectors so hard? Is there a chance they may fail?
Old Jan 11, 2004 | 07:06 PM
hondatim's Avatar
Default Re: overclocking stock B16 injectors (b20bvtec'd)
at 50 psi, not a big chance of failure. Although you are pushing the injectors a bit harder than stock pressure, stock injectors can generally handle about 75%-80% duty cycle. If you really wanted to solve the problem, purchase some 270-310cc injectors and fuel pressure at 50 psi static pressure. This would be a better set up than just taxing your stock injectors with the extra fuel pressure.
94typeR
Jun 22, 2007 07:44 PM
killerpenguin21
Apr 27, 2007 03:17 PM
OH_1fstgsr
Nov 10, 2006 12:15 PM
allnaturalb16
Oct 16, 2006 01:51 PM
