p30 pistons ?
Old Jan 11, 2004 | 02:04 PM
ras's Avatar
ras
Default p30 pistons ?
has anyone tried p30 pistons in there itr and how much of a difference is it .
Old Jan 11, 2004 | 03:37 PM
esponet's Avatar
jdm p30 will give you higher comp. ratio but not worth the time and money, would rather recomend ctr pistons if you were replacing piston and like to stay with honda oem slugs
my .001c
Old Jan 11, 2004 | 11:36 PM
sgT's Avatar
sgT
Default Re: p30 pistons ? (ras)
USDM p30/JDM PR3 makes about 11.2 in a b18c
JDM P30 makes about 11.4
They will have to be modified slightly to work properly in a b18c
Good for a mild setup
ojrapedmyfather
Guest
Posts: n/a
wow!
Old Jan 11, 2004 | 11:40 PM
JDMHN8's Avatar
Default Re: p30 pistons ? (sgT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sgT &raquo;</TD></TR><TR><TD CLASS="quote">They will have to be modified slightly to work properly in a b18c</TD></TR></TABLE>
How so? I was under the impression that these went right on the B18C/B16B rods with no mods at all, unlike putting an ITR piston on a B16A/B18A rod...
Old Jan 11, 2004 | 11:45 PM
sgT's Avatar
sgT
Default Re: p30 pistons ? (JDMDA9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMDA9 &raquo;</TD></TR><TR><TD CLASS="quote">
How so? I was under the impression that these went right on the B18C/B16B rods with no mods at all, unlike putting an ITR piston on a B16A/B18A rod...</TD></TR></TABLE>
The piston skirt does not clear the oil jet.
Old Jan 12, 2004 | 12:30 AM
Rhetoric's Avatar
The piston skirt does not clear the oil jet.</TD></TR></TABLE>
Would this be the same for the Ctr as well?
Old Jan 12, 2004 | 12:47 AM
sgT's Avatar
sgT
Default Re: p30 pistons ? (Rhetoric)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rhetoric &raquo;</TD></TR><TR><TD CLASS="quote">
Would this be the same for the Ctr as well?</TD></TR></TABLE>
You would think so, but i havent run into any clearance problems yet.
hondavtec24
Engine Management and Tuning
May 8, 2017 01:26 AM
cygnusX1
Jul 26, 2004 03:57 PM
FastAllmotorLsVtec
31
Apr 10, 2004 02:25 PM
ErikDaGenErik
Jun 24, 2003 10:49 AM
