ECU Code 20 -> Car dies out
Old Jan 11, 2004 | 11:33 AM
ek4life's Avatar
Default ECU Code 20 -> Car dies out
I just finished a 97 GSR swap in my 96 civic and my ECU is coming up with Code 20. I had this exact problem with stock DX motor, a few weeks before I did the swap. We were able to start the car fine, but I just took the car out today for a test drive. When I was driving down the street, when i would get on the gas the car felt like it was about to die, so I let off the gas and it would go back to idle. So i pulled over and tried to rev the car up and I had the same problem. When I would get on the gas, the car would start to die but I would just let go and it would return to idle. So I heard it may be the alternator so I do the test, where you leave the car running and disconnect the ground terminal off the battery, and if it dies that means the alternator may be shot. So i disconnected it and the car died. So I reconnected the terminal and now the car would crank but just die right after you stop turning the key. If you keep cranking the ignition, it would crank but then just die out. I also noticed that the speedometer wasnt working but the tach was on my SI cluster, if that has any relation to my problem. The weird thing is I thought of replacing the alternator, but I had this same code on my old motor as well, so I really dont think both alternators could have been shot, maybe something is shorting it out? But can anybody help me out, because I am clueless right now.
Old Jan 11, 2004 | 11:36 AM
ek4life's Avatar
Default Re: ECU Code 20 -> Car dies out (ek4life)
Just got back from checking it out again. So I checked the incar fusebox and it turns out that the Alternator Sensor Fuse was blown, so I replaced it. Now the car starts up, but when I rev it, it feels like its going to turn off again, it pretty much hesitates when you tap the gas. Some advice please...
Old Jan 13, 2004 | 08:15 PM
JTB's Avatar
JTB
check the engine harness under the intake manifold there is some wires that rub on the black bracket and cause that fuse to blow and cause the symptoms you descrobe usally it is the black wire , it is very common on the civics i get them like this all the time at work let me know if this fixes it.
Luward
Jul 10, 2009 09:34 PM
peej
Jan 22, 2009 09:21 PM
ek4life
Mar 12, 2004 09:11 AM
adam
Nov 13, 2001 06:45 PM
