Anyone Here with the Greddy Turbo on their ITR?
The Drag Kit is out of the question for me since I won't pass emissions without having to take the turbo off. Anybody have an ITR with the Greddy Kit? What kind of power should I expect from the stock boost level?
I have seen 2 of them installed on Gs-r's.They only made high 190's.There is an import lifestyle vid that has them installing it on a gs-r.From what I can see of the dyno it made around 190 or so.I couldn't justify doing a turbo unless it made bigger #'s than that.Hope this helps some.
Vonte' on here is geting his Rev Hard Stage 2 put on this week. We are going to go to the 1/4 mile track next weekend and see what it runs. I am not sure about the whp though.
Greddy kit is too expensive for what it makes. get the drag or take the 3500-4k you`d spend on the greddy kit and do a decent high comp all motor setup.
Ryan
[Modified by vtecvoodoo, 8:05 PM 9/28/2001]
Ryan
[Modified by CPR, 3:10 PM 9/28/2001]
That depends on where you are.
Since you are in Virginia, some places will pass visual so long as all
the emissions related equipment are in place and functional.
Some will look at the turbo and laugh at you. Just gotta find a good place.
they are weak. get the drag and an illegal smog
to answe the question on the greddy kit.. there is smoeone on this board by name of "spooncivic" he has on on the ITR motor in a hatch.. i think he wants to upgrade it too due to low HP numbers.. not sure on that one though..
go drag or revhard.. w/headgasket
Well, since I'm in VA, I won't have to worry about the CHP. If I can make a RELIABLE ~250whp with the Greddy Kit, pass emissions, and have a relatively quiet exhaust note, then I think I will go that route. If not, then I'm going back to the original plan of Toda Spec Bs.
Acura97GSR
Mar 4, 2002 10:53 PM
Integra187
Nov 24, 2001 08:19 PM
