1500 idle? (searched)
Old Jan 10, 2004 | 07:33 PM
stRodda's Avatar
Default 1500 idle? (searched)
about a week ago i noticed my throttle getting a little sticky, and sometimes after letting on the gas, the throttle wouldnt go allthe way down to 0%. i had the tb cleaned and everything was great for a coupe days.
the throttle is still fine, no sticking at all, but my idle is very high. i had a little problem prior to the tb cleaning, but afterwards it was back to normal. now when im in neutral the throttle still reads 0%, but its idling around 1500.
if i tap the gas, it will rev up and drop down to 850 for a sec, then will raise back up to the mid 1000's. the idle isnt jumping around, it holds steady... just alot higher than it should. does that still sound like a iacv problem? and my idle control is turned all the way down.
i also read about checking for vacuum leaks... what hoses should be checked? i dont know much about that stuff. if you have any pics thatd be great.
thanks.
Old Jan 10, 2004 | 07:43 PM
spnbb2
Guest
Posts: n/a
1500 idle is normal
Old Jan 10, 2004 | 07:46 PM
fengxzhang's Avatar
I thought normal idle is from 700-800?
Old Jan 10, 2004 | 08:50 PM
stRodda's Avatar
Default Re: (Ludinitup)
no way 1500 is normal.
Old Jan 11, 2004 | 01:20 AM
see_our_vtec's Avatar
Default Re: (stRodda)
well if 1500 is normal, then so is my idle surge
Old Jan 11, 2004 | 01:22 AM
ludeR917's Avatar
Default Re: 1500 idle? (stRodda)
i got the same problem, could it be the cold weather?
Old Jan 11, 2004 | 01:59 AM
Cottonwoodz's Avatar
Default Re: 1500 idle? (ludeR917)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludeR917 &raquo;</TD></TR><TR><TD CLASS="quote">i got the same problem, could it be the cold weather? </TD></TR></TABLE>
The engine is going to idle high, untill it is warmed up. That is what the fast idle valve does, lets a little air past the throttle plate when it's cold, which raises the idle..(Which is why it has coolant hoses running through it, so when it warms up to the right temp, it closes)
Old Jan 11, 2004 | 05:32 AM
TruNinja619's Avatar
who told u that lie????
Old Jan 11, 2004 | 09:13 AM
jdm22vtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ludinitup &raquo;</TD></TR><TR><TD CLASS="quote">1500 idle is normal</TD></TR></TABLE>
ummm definitely not.
700 - 800 is normal.
it should only idle that high on a cold start for a few minutes. Then back down to 700.
Old Jan 11, 2004 | 12:07 PM
skunk2lude01's Avatar
damn guys dont you know you have to let your car warm up. My car starts around 1500 as well on a cold start and I sit there 3-4 minutes and my idle goes back to 800 every time.
Old Jan 11, 2004 | 12:28 PM
Matgallis's Avatar
Default Re: (skunk2lude01)
800? damn that seems a little high. Somewhere under the hood it says...
I believe mine idles below 500
EDIT:nevermind, it must have been some other car...
Old Jan 11, 2004 | 01:18 PM
stRodda's Avatar
Default Re: (98 Prelude)
of course i let it idle til it warms up. i dont put it in gear until it is totally warm, but thats not what im talking about.
ill be cruising around town and come to a light... stop and put it in neutral. thats when it jumps up. i dont want to adjust the fast idle valve like ive read some do, cause then itll just stay low and take longer to warm up.
i noticed it happen the worst after i had been under hard acceleration on the freeway. if there was air in the line would flushing the coolant system fix that problem?
and does this sound like a iacv problem? or does that usually cause an erratic idle
Old Jan 11, 2004 | 01:54 PM
PetroGuyX's Avatar
Mine idle's at about 1500 when the engine's cold, after that i think mine's 7-800
Old Jan 11, 2004 | 02:47 PM
supaZZZleepa's Avatar
Default Re: (PetroGuyX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PetroGuyX &raquo;</TD></TR><TR><TD CLASS="quote">Mine idle's at about 1500 when the engine's cold, after that i think mine's 7-800</TD></TR></TABLE>
correct
Old Jan 11, 2004 | 05:00 PM
turbolude92's Avatar
do you happen to have APC stickers all over your car as well?? 1500 is definitely not normal. 700-800 is normal. check your idle screw. my car did the same thing cuz i was stupid and let one of buddies mess the screw. but anyways....dont mess with it yourself just take it to a honda shop. they shouldtn charge you anything to adjust that. also check the fast idle control valve and make sure that is clean as well. since you said it is not surging and steadily staying at 1500 then it should be the idle screw.
Old Jan 11, 2004 | 05:16 PM
specalk's Avatar
1500 cold warm 8-700 when engines warm or warm outside car idles at 1k at startup and 700 normal,
also if i was u guys id check the coolant passage lines on the IAC and fast air because mine was allmost blocked up and it cause engine vibrations
Old Jan 11, 2004 | 05:27 PM
spnbb2
Guest
Posts: n/a
in cold weather it is<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stRodda &raquo;</TD></TR><TR><TD CLASS="quote">no way 1500 is normal.</TD></TR></TABLE>
Old Jan 11, 2004 | 05:30 PM
spnbb2
Guest
Posts: n/a
Default Re: (turbolude92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">do you happen to have APC stickers all over your car as well?? 1500 is definitely not normal.</TD></TR></TABLE>no i dont, do you happen to have a gigantic ***** in your rectum?
i was referring to cold weather...somethign u prolly dont have being in SC
Old Jan 11, 2004 | 06:39 PM
99spanishGT
Guest
Posts: n/a
mine idles at 200!!!
Old Jan 13, 2004 | 04:32 PM
you in no way made reference to cold weather. if you were more clear on your statements then it would not have sounded so stupid.
99d-series
May 18, 2009 04:51 PM
mad21kid
Feb 18, 2008 12:52 PM
b_serious
Feb 8, 2006 05:42 PM
MeanGreenEG9
Mar 6, 2003 09:19 PM
chirp2hrd
Oct 13, 2002 01:36 AM
