Need some quick sway bar help
Old Jan 10, 2004 | 07:14 PM
onePOINTsix's Avatar
Default Need some quick sway bar help
my car didnt some with a stock sway bar in front or rear, found one on ebay, can i use it? it doesnt have mounts but ST bushings will be ordered, and end links what should i use?
edit: it's a front bar
Old Jan 10, 2004 | 09:37 PM
vtekstorm's Avatar
Default Re: Need some quick sway bar help (Sideout)
me personally i wouldnt buy from ebay. id rather get afresh new sway bar fresh out the box wit all the hardware so u wont have to be dickinga round trying to find pieces to make it work and fit. but i think enegry suspension might sell a kit for bushings and end links. im not sure. good luck
Old Jan 11, 2004 | 03:19 PM
ttt, going to buy it still looking for info
Old Jan 11, 2004 | 04:45 PM
Vitt1's Avatar
I would rather go to the local wrecking yard and buy one from there, especially a front one. Around here I can get one front one cheap. Also, make sure that it fits your car, but as mentioned above, I wouldn't buy from ebay until I checked for a local used one and saved on shipping too.
For the rear you're going to want aftermarket anyway because most stock are not thick enough. The ST has a F/R set for a decent price btw. ITR is cheap for the rear. You probably should get new OEM endlinks, because you want good bushings, but another thing you can use (on the rear at least) is buy rod end links. Good ones cost about the same as OEM endlinks I think.
Old Jan 11, 2004 | 05:32 PM
pornstarSR's Avatar
Default Re: Need some quick sway bar help (Vitt1)
well what car do you have.
if you have a civic, any lower model(dx/lx/vx) didnt have a front swap bar...92-up
not sure about 90 hatch....but you should check it out
and in order to put one on you have to either swap lower control arms from an ex, or get the ST mount kit....not just any old endlinks
Old Jan 12, 2004 | 11:02 AM
Vitt1's Avatar
Default Re: Need some quick sway bar help (pornstarSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pornstarSR &raquo;</TD></TR><TR><TD CLASS="quote">well what car do you have.
That's true. I wrote my reply with the assumption that you were aware that you needed LCAs with holes for the endlink bolts.
Old Jan 12, 2004 | 02:22 PM
vtekstorm's Avatar
if u buying it from ebay and u said you are u better make sure that te bar comes wit all the mounting brackets and hardware or youll neva get that thing on. and u can buy a s.t kit front and rear for pretty cheap price wit all hardware and brackets. ive known ppl to buy something from ebay and when the product came in it was the wrong product, pieces were missing, didnt fit but your car yrou money
Old Jan 12, 2004 | 03:15 PM
mrchris386's Avatar
Default Re: Need some quick sway bar help (vtekstorm)
edit: my bad i clicked back on the wrong thread
killercrx91
Jun 21, 2009 06:08 PM
Funkin Flux
Suspension & Brakes
Apr 24, 2009 01:28 PM
ef9itb
Jan 25, 2008 09:05 PM
carrnut21
Dec 12, 2006 07:40 PM
