What bracket do I need? QUICK PLEASE!!!
I'm putting a 98 b18c1 into a 92 civic dx hatchback, I have all the mounts, and all the brackets except for 1. The bracket that connets to the mount on the upper timing belt side is what I need. Someone help please!!
Here is the timing side:
This is what the mount looks like that I have for the timing side, it has 3 holes:
And this is the bracket that I was told was needed for the timing side, This bracket doesnt seem like it would work to me!
I have been working on this damn swap for 1 week now, and have had problems everyday working on it. This is all I need to do to get the motor in, so please respond.
Modified by J.R. at 6:56 PM 1/10/2004
Modified by J.R. at 6:58 PM 1/10/2004
Modified by J.R. at 7:01 PM 1/10/2004
What motor did the braket that is on the engine come off of. If it came frome a 98 gsr, then it should have no angle to it. You need a bracket from a 94+ integra where the mounting studs are parallel to the side of the engine. The extra bracket you show in the pice dosn't have the mounting studs and the holes are angled. The mount you have might work with the right bracket but i'm not positive what the application for that specific mount is. If interested, i have a bracket for $50 shipped. It was used when i had my b16a in my 92 cx with stock integra mount.
