how can you tell if its type r tranny besides the code s80 and lsd print
if you look into a LSD, you will not see a hole in center, a regular differential will be open down the center and you will see right through it down the cv joint holes
it's the other way around ...regular diff have shaft thru to hold spider gear .. and lsd you can see thru it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B20vtec86crx »</TD></TR><TR><TD CLASS="quote">it's the other way around ...regular diff have shaft thru to hold spider gear .. and lsd you can see thru it</TD></TR></TABLE>
yup, next step is cracking the tranny itself.
b18avtec(A!!M0TOR)
Jan 29, 2007 03:22 PM
