Please help me on my 5 lug!!!
I am doing a conversion on a 94 integra rs and i was wondering what axles do i need, because it seems like the rs axles are smaller than the gsr so do i need a gsr axles to make this fit?
Whats that rappers name, Ludacris?
94-Up tegs should share the same axles size((regardless of model) unless they are the coveted JDM ITR...
What kind of 5 lug did you get USDM or JDM?
All usdm axles should be the same. I think the JDM ITR axles are bigger, but the jdm ctr axles are the same as usdm integra axles. I might be wrong...id do more research
usdm and CTR and JDM ITR (97 and below) had 26 spline outer spindle with 32 mm axle nut
98+ JDM ITR had 28 spline outer spindle with 36 mm axle nut.
so if you have a 98+ JDM ITR 5 lug, then you need 98+ JDM ITR axles.
otherwise your axles should work
snowboardgeek1
10
Sep 4, 2007 09:07 PM
jdmjohn02
Jan 11, 2004 07:56 PM
oem
Jan 27, 2003 08:54 PM
