5 lug converion on a rs? Need help on axles!!
I am doing a conversion on a 94 integra rs and i was wondering what axles do i need, because it seems like the rs axles are smaller than the gsr so do i need a gsr axles to make this fit?
not JDM 5 lug conversions. The axles spline has a bigger diameter. I just changed mine.
Well I have a B18c swap and was running 94+ teg axles until I got my JDM 5 lug swap, where I had to get the JDM ITR axle too.
If you're using a USDM 5 lug swap then you need to get 32mm axles, what Dropspeed said. If you're going to be using a JDM 5 lug swap then you're going to have to find 36mm JDM axles. HTH.
Ed
Ed
Ran into the problem of the Bigger axles when my friend did the 5lug on his 96. Hes still running sohc. I believe Larry Jr. at Import Auto Salvage traded out his parts with usdm.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmgarage »</TD></TR><TR><TD CLASS="quote">where u get your jdm axles at?</TD></TR></TABLE>
You call yourself JDMgarage and don't know where to get JDM parts!!!!!
Good luck finding those at any local store, You will have to hook-up with a JDM salvage yard or importer to get the correct axles. As someone else stated Larry Jr. at import auto salvage I know can get them.
Mattj
Mattj
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmboi2004 »</TD></TR><TR><TD CLASS="quote">its just kool when you have type r wheels and bigger brakes on your car</TD></TR></TABLE>
Well if thats what floats your boat......
I'd still sell it and buy a USDM setup, if 5 lug is your thing. Less hassle.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmboi2004 »</TD></TR><TR><TD CLASS="quote">if i can't find these axles i guess thats the only way to go.</TD></TR></TABLE>
As per your other post, contact Steve Sakai (sgT): Steve@sgt-racing.com
He has the 36 mm axkes we just took off my car for sale. Ed
