Can I install squirters in an ls block to get a GSR-like block
Old Jan 10, 2004 | 02:17 PM
7rrivera7's Avatar
Default Can I install squirters in an ls block to get a GSR-like block
I can't find a GSR block and can't afford a type r block but I like the squirters. Can they be installed in a B18a?
Old Jan 10, 2004 | 02:29 PM
speedDOHCtors's Avatar
Default Re: Can I install squirters in an ls block to get a GSR-like block (7rrivera7)
If you are talking about Oil Squirters then no, you can't. GSR Blocks are the only blocks that have them. Sorry man. Save some money, and let me know. Might be able to find a block for you.
Old Jan 10, 2004 | 03:54 PM
HXMan's Avatar
Default Re: Can I install squirters in an ls block to get a GSR-like block (project_imports)
Um, you should only answer questions if you know the RIGHT ANSWER to the question.
You can install oil squirters....I know some drilling and tapping is required. I'm not sure of the exact process, you may want to do a search.
Old Jan 10, 2004 | 04:08 PM
hotintegranights's Avatar
Default Re: Can I install squirters in an ls block to get a GSR-like block (HXMan)
stop trying to make money off members and help them out.
they can be installed onto your ls b18a/b18b block but i was quoted 200 at one machine shop and 230 at another one its not an easy process,plus used oil squirters go for around 40-50(set). i would recomend you just save that money and get some forged pistons around $400-500 bucks which dont need oil squirters at high rpm like the stock pistons.
Old Jan 10, 2004 | 07:27 PM
Sliced Beard's Avatar
go to this link
chad put them in a b20 block
essentially the same thing as a ls
https://honda-tech.com/zerothread?id=714210
look at the seventh picture down and enjoy
btw it costed about 200 bux to get this done but is very
beneficial with stock pistons and makes for a more reliable engine
Old Jan 11, 2004 | 09:12 AM
7rrivera7's Avatar
Default Re: Can I install squirters in an ls block to get a GSR-like block (hotintegranights)
You see...you can get an intelligent response from H/T members!
So oil squirters are for stock pistons...I never thought of that. I thought it had to do with the reliablility of an ls/vtec at high rpms which I do now with my built B16 (9k).
I will be running Endyns (they are forged) so I don't need the squirters right? So where can I get a good write up on how to build an ls/vtec correctly? I really want to rev the hell out of the engine!
Thanks!
Old Jan 11, 2004 | 12:30 PM
so you wanna rev the hell out of the engine then you ll def need the endyn or z10 block girlde, and make sure you get everything balanced you dont want anything vibrating at 9000rpm. only site i know that has info on building up the ls/vtec is http://www.c-speedracing.com and you can also check http://www.b20vtec.com. for some info.
Old Jan 11, 2004 | 01:11 PM
hybridmoose's Avatar
Oil squirters are only there for cooling purposes at high RPM. Just buy some good new pistons and install a block girdle you will be fine.
Old Jan 11, 2004 | 01:16 PM
photec3's Avatar
Default Re: Can I install squirters in an ls block to get a GSR-like block (hybridmoose)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridmoose &raquo;</TD></TR><TR><TD CLASS="quote">Oil squirters are only there for cooling purposes at high RPM. Just buy some good new pistons and install a block girdle you will be fine.</TD></TR></TABLE>
Exactly
Justlearning95
Sep 21, 2016 07:09 AM
russianswty
Oct 17, 2006 03:09 PM
JUN-DA6
Jul 27, 2005 09:30 PM
JDM B16 EK
Jan 28, 2005 06:47 PM
pvt_awol
Dec 17, 2004 11:28 AM
