vss question with b-series swap
Old Jan 10, 2004 | 12:23 PM
Spunkster's Avatar
Default vss question with b-series swap
I have a bseries with a hydro tranny in my 87 teg. I can use the standard electronic speed senor mounted in the tranny, but then i have no speedo. My other option is to mount the old cable sender from the d-series tranny into the hydro tranny. This allows the speedo to work, but I'm not sure where i need to tap into for the propper vss signal to the ecu.
I suspect that it's the cruise control speed sensor signal that i need to also send to the ecu on OBD0 pin B16. I tried the standard PGMFI signal from the cluster with is listed at 4-5V at 10 mph.
The cruise control speed pulser generates 4 pusles per 1 cable revolution. I have been unable to determine what the OBD1 ecu is looking for on pin B10.
Any help would be greatly appreciated so I can get rid of the VSS error when using the cable driven speedo.
rasta420
Aug 28, 2007 06:54 PM
crxdxsir
Nov 13, 2006 09:36 PM
eleciv7
Nov 22, 2005 06:47 PM
Spunkster
Jan 12, 2004 03:40 PM
Spunkster
Jan 10, 2004 05:22 PM
