Just did the head.. what could be wrong
Old Jan 10, 2004 | 10:36 AM
IntegracinGSR's Avatar
Default Just did the head.. what could be wrong
I just did a new headgasket.. studs.. everything is back together.. its gettin fuel.. its gettin spark and the motor is turning but it wont start.. what else should i check?
Old Jan 10, 2004 | 10:38 AM
Default Re: Just did the head.. what could be wrong (IntegracinGSR)
bump.. someone.. anyone...
Old Jan 10, 2004 | 10:47 AM
Turbogixxer's Avatar
Check your timing (cam and ignition) and see if you have compression. Check your grounds too.
Old Jan 10, 2004 | 10:48 AM
thanks
Old Jan 10, 2004 | 11:10 AM
thats all fine.. anything else i could check.. im really stumped
Old Jan 10, 2004 | 11:37 AM
FULLTHROTTLE's Avatar
Default Re: (IntegracinGSR)
Is it cranking really fast and sounding weird? its possible its slightly flooded and needs to be cleared so it can start.
Old Jan 12, 2004 | 08:51 PM
it was definately flooding alot.. the plugs came out covered in gasoline.. thx for the input..
Old Jan 12, 2004 | 11:47 PM
Altered's Avatar
Is the motor grounded properly?
Old Jan 13, 2004 | 02:27 AM
b00sted93Hatch's Avatar
Default Re: Just did the head.. what could be wrong (Altered)
Turn your crank to TDC. Take a look at your cam gears and make sure both of them are aligned at TDC.
Old Jan 13, 2004 | 05:11 AM
b18cx's Avatar
Default Re: Just did the head.. what could be wrong (allMotor93Hatch)
Maybe check the gruond thats supposed to be attached to the thermoustat housing. I know I left it off one time and the car would not start because of it.
Old Jan 13, 2004 | 04:13 PM
Tire Monkey's Avatar
sounds like blue *****.
oops. only read subject
91grape
Aug 6, 2012 06:31 PM
honduh8993
May 5, 2007 09:56 PM
quikcivic94
Jun 14, 2006 11:09 AM
dstahl01
Aug 12, 2005 07:05 PM
xteg95
Jun 18, 2003 09:50 PM
