Wheels Shake.....need help
Old Jan 10, 2004 | 08:26 AM
jdmstreethatch's Avatar
Default Wheels Shake.....need help
Okay, about 3 weeks ago i had the left rear wheel bearing changed because my steering wheel and wheels shook really bad at all speeds. well, i put my stock rims back on today and now the same thing is happening. The right side of my car is fine but, on the left side both wheels wobble really bad when driving. Also, my steeing wheel shakes really bad.
any idea what this could be?? and why would changing my wheels back to stock affect it??
thanks
chris
Old Jan 10, 2004 | 08:44 AM
RCautoworks's Avatar
Default Re: Wheels Shake.....need help (jdmstreethatch)
Whens the last time you had those tires balanced ? I'd say get them balanced then see what happens.
Old Jan 10, 2004 | 10:21 AM
yeah, i just put back on my 15's and now its fine. i held out the steelies and bounced them on the ground and they dont bounce straight up they bounce to the side. so i guess i need to get them balanced.
any idea how much that costs??
Old Jan 10, 2004 | 10:38 AM
Default Re: (jdmstreethatch)
I don't think it should cost to much, it only takes about 20 minutes if the guy knows what he is doing. And its not really hard to do.
Old Jan 10, 2004 | 10:43 AM
Default Re: (90blackcrx)
so you think thats what the problem is then??
Old Jan 10, 2004 | 11:10 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmstreethatch &raquo;</TD></TR><TR><TD CLASS="quote">so you think thats what the problem is then??
Well its where I would start off and get that out of the way. After you put your regular rims on did the car shake ? If not its defiantly the steelies. So maybe there unbalanced, or maybe the rim is bent.
Old Jan 10, 2004 | 12:32 PM
yeah it stopped when i put my rotas on. the shaking of the steering wheel and wobbling wheels both stopped. also, when i had my steelies on, there was alot of slack in the steering wheel.
Old Jan 10, 2004 | 03:38 PM
Cynical 1's Avatar
Just go to a tire store and get a balance. Should be no more that $30.
Old Jan 10, 2004 | 07:19 PM
nsxmatt's Avatar
Default Re: (Revolveu2)
There are a couple of places in town that do a runout test with a balance. That will tell you if the rim is bent and if the balance is off. A rim that is bent will balance but with alot of weight and you won't fix the problem.
Old Jan 11, 2004 | 12:40 AM
SyDuck's Avatar
Default Re: (nsxmatt)
go to costco to get balance lol... thats where i got minez... u get this dope *** costco sticker for free too... another factor is that ur rotors mite be f-ed up?
Old Jan 11, 2004 | 12:51 AM
what would my rotors have to do with anything. the shaking/wobbling completely goes away when i put the 15's back on.
Old Jan 11, 2004 | 05:06 AM
nsxmatt's Avatar
Tie rod ends or a worn rack could cause the problem. Also a bad alignment could cause some shake and pull.
Old Jan 11, 2004 | 10:19 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxmatt &raquo;</TD></TR><TR><TD CLASS="quote">Tie rod ends or a worn rack could cause the problem. Also a bad alignment could cause some shake and pull. </TD></TR></TABLE>
If it was tie rods or a worn rack, or a bad alignment those things would all occur with the rotas on to. Those problems would not just go away once he put the rotas on.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxmatt &raquo;</TD></TR><TR><TD CLASS="quote"> A rim that is bent will balance but with alot of weight and you won't fix the problem.</TD></TR></TABLE>
Thats right, but any good shop would catch a bent rim and not even try to balance. Your never suppose to balance a tire/rim if it needs more then 3 ounces of weight.
Old Jan 11, 2004 | 11:13 AM
SKDRCR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmstreethatch &raquo;</TD></TR><TR><TD CLASS="quote">what would my rotors have to do with anything. the shaking/wobbling completely goes away when i put the 15's back on.</TD></TR></TABLE>
i doubt it,
it would probably shake like that with either of the wheels
Old Jan 11, 2004 | 04:28 PM
AlvinHuyN's Avatar
get an alignment for your car.
msinsky14
49
Jan 27, 2011 08:10 AM
dlc
Jun 18, 2010 06:29 AM
G2_Fella
May 8, 2009 08:38 AM
cocoluco
Suspension & Brakes
11
Mar 11, 2009 10:03 PM
SpeedoKing
10
Jul 13, 2007 06:53 PM
