ITR wheel stats???!?!!
Old Jan 9, 2004 | 09:32 PM
daddymaxx's Avatar
Default ITR wheel stats???!?!!
what ar ethe ITR wheel stats?
15x6.5 +40 offset? obviously 5.114.3
Anybdoy know the weight ?
Old Jan 9, 2004 | 09:34 PM
Bbasso's Avatar
Default Re: ITR wheel stats???!?!! (daddymaxx)
wheelweights.net I think...
ZygSpeed's Avatar
first of all the stock USDM is 15 x 6
Weighs about 15.6 lbs
Old Jan 9, 2004 | 09:35 PM
daddymaxx's Avatar
ok tha'ts wha tI needed to know. so it's 15x6 wha tis teh offset?
Old Jan 9, 2004 | 09:40 PM
ZygSpeed's Avatar
Default Re: (daddymaxx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by daddymaxx &raquo;</TD></TR><TR><TD CLASS="quote">ok tha'ts wha tI needed to know. so it's 15x6 wha tis teh offset? </TD></TR></TABLE>
Might be +50 but I'm not sure.
Why does it matter?
http://www.itrsport.com might have some info for you.
Old Jan 9, 2004 | 09:41 PM
daddymaxx's Avatar
I got some 15" ITR wheels right now, I am replacing them with some rotas... what offset should I be getting?
Old Jan 9, 2004 | 09:51 PM
ZygSpeed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by daddymaxx &raquo;</TD></TR><TR><TD CLASS="quote">I got some 15" ITR wheels right now, I am replacing them with some rotas... what offset should I be getting? </TD></TR></TABLE>
If you have ITR wheels then see for yourself what the stampings say on the inside/back.
Otherwise ask the person/company you're buying your wheels from.
Old Jan 9, 2004 | 10:08 PM
Holding monSteR's Avatar
you have another set of itr rims? I tried to buy a set off you a month or so ago. Yeah the offset is +50. Rota only has +40 offset for 15" wheels for itr and +40 and +45 in 16" and up. Both should probably work fine.
Old Jan 9, 2004 | 11:45 PM
Downey's Avatar
stock R wheels are
15x6
+50mm offset
16 lbs
Old Jan 10, 2004 | 06:26 AM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
Default Re: (zygspeed)
ziggy was correct on all his specs.
15" oem itr wheels:
15x6
+50mm offset
15.6 lbs each w/ valvestem
Old Jan 10, 2004 | 12:01 PM
1GreyTeg's Avatar
Default Re: (rodney)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rodney &raquo;</TD></TR><TR><TD CLASS="quote">ziggy was correct on all his specs.
15" oem itr wheels:
15x6
+50mm offset
Yeah but was 15.6 lbs with the blue Volk valvestems, the black Mugen ones or the cheapo rubber ones?
What no cool pics with the famed Smithsonian accurate glass bathroom scale? I surely do miss those. Can you tell I'm bored as phawk at work?
godskrilla
Jan 15, 2008 01:26 PM
BringIT
Nov 28, 2006 04:39 AM
L-CON1
Sep 22, 2005 07:22 AM
DonKey or Horse
Aug 10, 2004 10:38 AM
REDTOPAlchemy
Jul 20, 2004 06:52 PM
